| How to read file in a Eclipse Plugin? [message #327175] | Sun, 13 April 2008 07:23  |  |
| Eclipse User  |  |  |  |  | Originally posted by: jefftymc.yahoo.com
 Hi All,
 In a plugin project I want to save and load info from
 "plugin.properties" file. This file is placed under the root folder.
 Code is like this:
 String pluginPath = null;
 URL bundleRootURL = TestPlugin.getDefault().getBundle().getEntry("/");
 try {
 URL pluginUrl = FileLocator.resolve(bundleRootURL);
 pluginPath = pluginURL.getPath();
 } catch (IOException e) {
 // get the plugin path such as
 // "D:/workspace/TestPlugin/"
 pluginPath = pluginPath.substring(1);
 Properties prop = new Properties();
 String path = pluginPath + "plugin.properties";
 InputStream is = new FileInputStream(path);
 prop.load(is);
 In Running & Debug mode it works well. But when I export the
 project to myplugin.jar and place it into Eclipse's plugin folder it
 didn't work.
 BTW: Loading from the file is for a PreferencePage. I download the
 some example source code and found that they all use like this: (in a
 PreferencePage)
 IPreferenceStore ps = getPreferenceStore();
 String s1 = ps.getValue(key1, value1);	// for save
 String s2 = ps.getString(key2);	// for load
 We can only choose IPreferenceStore for saving & loading? Cann't we
 do the same with reading & writting from/into the file in the plugin
 project?
 Would u please help me with that? Thanks in advance!
| Re: How to read file in a Eclipse Plugin? [message #327239 is a reply to message #327209] | Mon, 14 April 2008 09:27   |  |
 "You may store data by yourself inside a directory you
 created for your plug-in or you may use the preference store"
 If what I want to load are not simple key/value paris, how to do
 that? i.e. I want to read a velocity template like:
 <html>
 <body>
 hi $name,
 This is the No. &number letters.
 <body>
 </html>
 As a matter of convenience I want to packed the template into the
 plugin jar file. When eclipse load the plugin how can I read from the file?
 In most cases the key/value paris that loaded from IPreferenceStore
 is enough, but if a special file is needed to read inside the plugin
 jar, must we use like this?
 IPreferenceStore ps = AbstractUIPlugin.getPreferenceStore();
 ps.setValue("template", "<html><body>hi $name,This is the No.
 &number letters.<body></html>");
 Achim Lörke wrote:
 > On Mon, 14 Apr 2008 09:39:21 +0800, jeffty <jefftymc@yahoo.com> wrote:
 >>    Errr... I c.
 >>    After setting in a preference page of Eclipse and restart Eclipse, I
 >> find that my configuration has been saved successfully. How Eclipse do
 >> that? It must write the info into a file but we don't know which one is it.
 > The preference settings are stored using IPreferenceStore, you can get
 > an instance using the AbstractUIPlugin.getPreferenceStore() method.
 > The data is stored in the workspace directory in a subdirectory called
 > ".metadata". You may store data by yourself inside a directory you
 > created for your plug-in or you may use the preference store (no need
 > to use the preference dialog for this, just store your data in
 > key/value pairs).
 > Achim
| Re: How to read file in a Eclipse Plugin? [message #327274 is a reply to message #327239] | Tue, 15 April 2008 02:58   |  |
 Anyway thanks to Merks and Achim, I've learnt much from you. :)
 > <html>
 >     <body>
 >         hi $name,
 >     <body>
 > </html>
 >>>    Errr... I c.
 >>> I find that my configuration has been saved successfully. How Eclipse
 >>> do that? It must write the info into a file but we don't know which
 >>> one is it.
 >> key/value pairs).
 >> Achim
| Re: How to read file in a Eclipse Plugin? [message #327276 is a reply to message #327239] | Tue, 15 April 2008 03:15   |  |
| Eclipse User  |  |  |  |  | On Mon, 14 Apr 2008 21:27:43 +0800, jeffty <jefftymc@yahoo.com> wrote:
 ><html>
 >     <body>
 >         hi $name,
 >     <body>
 ></html>
 You may create a file in the workspace .metada directory. I'm not
 familiar with the API, I believe you will find it in the IResource
 surroundings, see IResource.getWorkspace(). You may also use
 BundleContext.getDataFile().
 To read from the plugins jar you can either use the BundleClassloader
 and call one of the *Resource* methods or you may use BundleFile to
 get your files.
 This is from memory and some brief glances at the API so please be
 carefull :-)
 Achim
 Achim Lörke
 Eclipse-Stammtisch in the Braunschweig, Germany area:
 http://www.bredex.de/de/career/eclipse.html
| Re: How to read file in a Eclipse Plugin? [message #327347 is a reply to message #327276] | Tue, 15 April 2008 20:46  |  |
 I'll try it,Thanks a lot!
 >> <html>
 >>     <body>
 >>         hi $name,
 >>     <body>
 >> </html>
 > get your files.
 > carefull :-)
 > Achim
FUDForum. Page generated in 0.05664 seconds
