Home » Eclipse Projects » Eclipse Platform » Execute a command from code
Execute a command from code [message #327168] Sat, 12 April 2008 08:42 Go to next message
Originally posted by: tom.eiswind.de
HI,
guess I have a edit command on my view toolbar.
Now I want that command to be executed on a double click on the views
selection. Command.execute needs an ExecutionEvent, is there an
appropriate way to construct such Event ?
Thanks for helping me
Thomas
Re: Execute a command from code [message #327169 is a reply to message #327168] Sat, 12 April 2008 12:26 Go to previous messageGo to next message
What I mean is that I only have the DoubleClickEvent that doesnt help.
How would you solve this ?
Thomas schrieb:
> HI,
> Thomas
Re: Execute a command from code [message #327180 is a reply to message #327168] Sun, 13 April 2008 09:59 Go to previous messageGo to next message
IHandlerService hs
= (IHandlerService) getSite().getService(IHandlerService.class);
hs.executeCommand("command.id", null);
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Execute a command from code [message #327267 is a reply to message #327180] Tue, 15 April 2008 01:45 Go to previous messageGo to next message
HI Paul,
I thought of that, but the handler needs a proper ExecutionEvent !
Paul Webster schrieb:
> IHandlerService hs
Re: Execute a command from code [message #327272 is a reply to message #327267] Tue, 15 April 2008 02:43 Go to previous message
Tried it works like a charm. Thought I needed an event !
Thomas schrieb:
> HI Paul,
>> IHandlerService hs
Previous Topic:Eclipse Forms and JFace Dialog
Next Topic:Composite preferred size
Current Time: Tue Oct 14 20:39:31 EDT 2025
Powered by FUDForum. Page generated in 0.04363 seconds
