Home » Eclipse Projects » Eclipse Platform » Re: java.lang.UnsatisfiedLinkError: no localfile_1_0_0 in java.library.path
Re: java.lang.UnsatisfiedLinkError: no localfile_1_0_0 in java.library.path [message #327090] |
Wed, 09 April 2008 12:34 |
--------------080702090104080105010706
Jeroen,
When I check my installation, I find it here:
./configuration/org.eclipse.osgi/bundles/261/1/.cp/os/win32/ x86/localfile_1_0_0.dll
So it looks like something must unpack it and put it there at some
point. I'll add the platform newsgroup to the "to" list of the reply.
Maybe someone will understand the cause of this exception...
Jeroen Lankheet wrote:
> I haven't found very much info on the www about the DLL, other than
> that it's present in almost every crash report of Eclipse as a loaded
> dynamic lib.
> Here is the full stack trace
> !SESSION 2008-04-09 07:23:11.998
> eclipse.buildId=unknown
> java.version=1.6.0_05
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Command-line arguments: -os win32 -ws win32 -arch x86 -clean -consolelog
> !ENTRY org.eclipse.core.resources 2 10035 2008-04-09 07:23:14.045
> !MESSAGE The workspace exited with unsaved changes in the previous
> session; refr
> eshing workspace to recover changes.
> !ENTRY org.eclipse.core.filesystem 1 1 2008-04-09 07:23:14.076
> !MESSAGE Could not load library: localfile_1_0_0.dll. This library
> provides pla
> tform-specific optimizations for certain file system operations. This
> library i
> s not present on all platforms, so this may not be an error. The
> resources plug
> -in will safely fall back to using java.io.File functionality.
> !STACK 0
> at java.lang.ClassLoader.loadLibrary(Unknown Source)
> at java.lang.Runtime.loadLibrary0(Unknown Source)
> at java.lang.System.loadLibrary(Unknown Source)
> at
> org.eclipse.core.internal.filesystem.local.LocalFileNatives. <clinit>(
> LocalFileNatives.java:32)
> at
> org.eclipse.core.internal.filesystem.local.LocalFile.fetchIn fo(LocalF
> ile.java:125)
> at
> org.eclipse.core.filesystem.provider.FileStore.fetchInfo(Fil eStore.ja
> va:275)
> at
> org.eclipse.core.internal.localstore.FileSystemResourceManag er.read(F
> ileSystemResourceManager.java:679)
> at
> org.eclipse.core.internal.resources.SaveManager.restoreMetaI nfo(SaveM
> anager.java:792)
> at
> anager.java:772)
> at
> org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.j
> ava:663)
> at
> org.eclipse.core.internal.resources.SaveManager.startup(Save Manager.j
> ava:1319)
> at
> org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:
> 1949)
> at
> org.eclipse.core.internal.resources.Workspace.open(Workspace .java:171
> 3)
> at
> org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPl ugin.java
> :363)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(Bund
> leContextImpl.java:999)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActiv
> ator(BundleContextImpl.java:993)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(Bund
> leContextImpl.java:974)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(Bundl
> eHost.java:346)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(Abstrac
> tBundle.java:260)
> at
> org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:
> 400)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFind
> LocalClass(EclipseLazyStarter.java:111)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(C
> lasspathManager.java:417)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalCla
> ss(DefaultClassLoader.java:189)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(
> BundleLoader.java:340)
> at
> org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClas
> s(SingleSourcePackage.java:37)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assIntern
> al(BundleLoader.java:405)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(Bundl
> eLoader.java:369)
> at
> eLoader.java:357)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(De
> faultClassLoader.java:83)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at java.lang.ClassLoader.loadClassInternal(Unknown Source)
> at
> org.eclipse.ui.part.FileEditorInputFactory.createElement(Fil eEditorIn
> putFactory.java:59)
> at
> org.eclipse.ui.internal.EditorReference.getRestoredInput(Edi torRefere
> nce.java:361)
> at
> org.eclipse.ui.internal.EditorReference.getEditorInput(Edito rReferenc
> e.java:324)
> at
> org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torRefere
> nce.java:591)
> at
> org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.ja
> va:426)
> at
> org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartR
> eference.java:592)
> at
> org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaH
> elper.java:263)
> at
> org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.
> java:1405)
> at
> org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManage
> r.java:939)
> at
> org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupT
> hreading.java:31)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> at
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.ja
> va:123)
> at
> org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
> at
> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
> at
> org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvi
> sor.java:801)
> at
> org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:
> 1342)
> at
> hreading.java:31)
> at
> va:123)
> at
> at
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
> at
> org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
> at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.ja
> va:289)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.jav
> a:461)
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> com.philips.aurora.tools.ia_workbench_application.Applicatio n.start(U
> nknown Source)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandl
> e.java:169)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runAppli
> cation(EclipseAppLauncher.java:106)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Ec
> lipseAppLauncher.java:76)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.ja
> va:363)
> at
> va:176)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown
> Source)
> at
> org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
> Ed Merks wrote:
>> Jeroen,
>> The post looks fine to me in Thunderbird. I've never seen a error
>> message like this. Perhaps showing the stack trace will provide more
>> information that someone might recognize the cause...
>>> Hi,
>>> I'm getting this error when starting my RCP app:
>>> I know it can safely be ignored, but I don't want exceptions in my
>>> console other than my 'own'.
>>> What's missing?
>>> Regards,
>>> Jeroen.
>>> BTW: Is anyone having trouble seeing their own posts with
>>> Thunderbird? I do!
<html>
<head>
</head>
Jeroen,<br>
<br>
<br>
When I check my installation, I find it here:<br>
<blockquote> ./configuration/org.eclipse.osgi/bundles/261/1/.cp/os/win32/ x86/localfile_1_0_0.dll <br>
</blockquote>
reply. Maybe someone will understand the cause of this exception...<br>
<br>
<br>
<blockquote cite="mid:fthl84$990$1@build.eclipse.org" type="cite">I
haven't found very much info on the www about the DLL, other than that
dynamic lib.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
-consolelog
<br>
<br>
<br>
session; refr
<br>
<br>
<br>
<br>
provides pla
<br>
library i
<br>
resources plug
<br>
<br>
!STACK 0
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
ile.java:125)
<br>
<br>
va:275)
<br>
<br>
<br>
<br>
anager.java:792)
<br>
<br>
anager.java:772)
<br>
<br>
ava:663)
<br>
<br>
ava:1319)
<br>
<br>
1949)
<br>
<br>
3)
<br>
<br>
:363)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
eHost.java:346)
<br>
<br>
tBundle.java:260)
<br>
<br>
400)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
eLoader.java:369)
<br>
<br>
eLoader.java:357)
<br>
<br>
<br>
<br>
<br>
<br>
putFactory.java:59)
<br>
<br>
nce.java:361)
<br>
<br>
e.java:324)
<br>
<br>
nce.java:591)
<br>
<br>
va:426)
<br>
<br>
eference.java:592)
<br>
<br>
elper.java:263)
<br>
<br>
java:1405)
<br>
<br>
r.java:939)
<br>
<br>
hreading.java:31)
<br>
<br>
<br>
va:123)
<br>
<br>
<br>
<br>
sor.java:801)
<br>
<br>
1342)
<br>
<br>
hreading.java:31)
<br>
<br>
<br>
va:123)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
va:289)
<br>
<br>
a:461)
<br>
<br>
<br>
nknown Source)
<br>
<br>
e.java:169)
<br>
<br>
<br>
<br>
<br>
<br>
va:363)
<br>
<br>
va:176)
<br>
<br>
<br>
Source)
<br>
<br>
<br>
<br>
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Jeroen,
<br>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
What's missing?
<br>
<br>
<br>
Jeroen.
<br>
<br>
BTW: Is anyone having trouble seeing their own posts with Thunderbird?
I do!
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------080702090104080105010706--
Re: java.lang.UnsatisfiedLinkError: no localfile_1_0_0 in java.library.path [message #327091 is a reply to message #327090] |
Wed, 09 April 2008 12:37 |
Originally posted by: yeronimuz.aol.com
Right, I don't have the 261 directory.
Ed Merks wrote:
> Jeroen,
>> dynamic lib.
>> session; refr
>> provides pla
>> library i
>> resources plug
>> !STACK 0
>> at
>> at
>> ile.java:125)
>> at
>> va:275)
>> at
>> at
>> anager.java:792)
>> at
>> anager.java:772)
>> at
>> ava:663)
>> at
>> ava:1319)
>> at
>> 1949)
>> at
>> 3)
>> at
>> :363)
>> at
>> at
>> at
>> at
>> eHost.java:346)
>> at
>> tBundle.java:260)
>> at
>> 400)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> eLoader.java:369)
>> at
>> eLoader.java:357)
>> at
>> at
>> putFactory.java:59)
>> at
>> nce.java:361)
>> at
>> e.java:324)
>> at
>> nce.java:591)
>> at
>> va:426)
>> at
>> eference.java:592)
>> at
>> elper.java:263)
>> at
>> java:1405)
>> at
>> r.java:939)
>> at
>> hreading.java:31)
>> at
>> va:123)
>> at
>> at
>> at
>> sor.java:801)
>> at
>> 1342)
>> at
>> hreading.java:31)
>> at
>> va:123)
>> at
>> at
>> at
>> at
>> va:289)
>> at
>> a:461)
>> at
>> at
>> nknown Source)
>> at
>> e.java:169)
>> at
>> at
>> at
>> va:363)
>> at
>> va:176)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> Source)
>> at
>> Ed Merks wrote:
>>> Jeroen,
>>>> Hi,
>>>> What's missing?
>>>> Regards,
>>>> Jeroen.
>>>> Thunderbird? I do!
Re: java.lang.UnsatisfiedLinkError: no localfile_1_0_0 in java.library.path [message #327092 is a reply to message #327091] |
Wed, 09 April 2008 12:40 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
This is a dynamic value and depends which ID OSGi assigns to your bundle
when started the first time.
Tom
> Ed Merks wrote:
>> Jeroen,
>>> loaded dynamic lib.
>>> -consolelog
>>> session; refr
>>> provides pla
>>> This library i
>>> resources plug
>>> !STACK 0
>>> at
>>> at
>>> ile.java:125)
>>> at
>>> va:275)
>>> at
>>> at
>>> anager.java:792)
>>> at
>>> anager.java:772)
>>> at
>>> ava:663)
>>> at
>>> ava:1319)
>>> at
>>> 1949)
>>> at
>>> 3)
>>> at
>>> :363)
>>> at
>>> at
>>> at
>>> at
>>> eHost.java:346)
>>> at
>>> tBundle.java:260)
>>> at
>>> 400)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> eLoader.java:369)
>>> at
>>> eLoader.java:357)
>>> at
>>> at
>>> putFactory.java:59)
>>> at
>>> nce.java:361)
>>> at
>>> e.java:324)
>>> at
>>> nce.java:591)
>>> at
>>> va:426)
>>> at
>>> eference.java:592)
>>> at
>>> elper.java:263)
>>> at
>>> java:1405)
>>> at
>>> r.java:939)
>>> at
>>> hreading.java:31)
>>> at
>>> at
>>> va:123)
>>> at
>>> at
>>> at
>>> sor.java:801)
>>> at
>>> 1342)
>>> at
>>> hreading.java:31)
>>> at
>>> at
>>> va:123)
>>> at
>>> at
>>> at
>>> at
>>> va:289)
>>> at
>>> a:461)
>>> at
>>> at
>>> nknown Source)
>>> at
>>> e.java:169)
>>> at
>>> at
>>> at
>>> va:363)
>>> at
>>> va:176)
>>> Source)
>>> at
>>> Ed Merks wrote:
>>>> Jeroen,
>>>> more information that someone might recognize the cause...
>>>>> Hi,
>>>>> java.library.path
>>>>> What's missing?
>>>>> Regards,
>>>>> Jeroen.
>>>>> Thunderbird? I do!
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: java.lang.UnsatisfiedLinkError: no localfile_1_0_0 in java.library.path [message #327093 is a reply to message #327092] |
Wed, 09 April 2008 13:28 |
Grant Gayed Messages: 2150 Registered: July 2009 |
Are you using 64-bit Windows by any chance? If so then the library is
currently not build for this arch, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=203812 .
Also see https://bugs.eclipse.org/bugs/show_bug.cgi?id=173272 .
Grant
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:ftidgi$suu$1@build.eclipse.org...
> Tom
> > Ed Merks wrote:
> >> Jeroen,
../configuration/org.eclipse.osgi/bundles/261/1/.cp/os/win32 /x86/localfile_1_
0_0.dll
> >>> loaded dynamic lib.
> >>> -consolelog
> >>> session; refr
> >>> provides pla
> >>> This library i
> >>> resources plug
> >>> !STACK 0
java.library.path
> >>> at
> >>> at
> >>> ile.java:125)
> >>> at
> >>> va:275)
> >>> at
> >>> at
> >>> anager.java:792)
> >>> at
> >>> anager.java:772)
> >>> at
> >>> ava:663)
> >>> at
> >>> ava:1319)
> >>> at
> >>> 1949)
> >>> at
> >>> 3)
> >>> at
> >>> :363)
> >>> at
> >>> at
> >>> at
> >>> at
> >>> eHost.java:346)
> >>> at
> >>> tBundle.java:260)
> >>> at
> >>> 400)
> >>> at
> >>> at
> >>> at
> >>> at
> >>> at
> >>> at
> >>> at
> >>> eLoader.java:369)
> >>> at
> >>> eLoader.java:357)
> >>> at
> >>> at
> >>> putFactory.java:59)
> >>> at
> >>> nce.java:361)
> >>> at
> >>> e.java:324)
> >>> at
> >>> nce.java:591)
> >>> at
> >>> va:426)
> >>> at
> >>> eference.java:592)
> >>> at
> >>> elper.java:263)
> >>> at
> >>> java:1405)
> >>> at
> >>> r.java:939)
> >>> at
> >>> hreading.java:31)
> >>> at
> >>> at
> >>> va:123)
> >>> at
> >>> at
> >>> at
> >>> sor.java:801)
> >>> at
> >>> 1342)
> >>> at
> >>> hreading.java:31)
> >>> at
> >>> at
> >>> va:123)
> >>> at
> >>> at
> >>> at
> >>> at
> >>> at
> >>> va:289)
> >>> at
> >>> a:461)
> >>> at
> >>> at
> >>> nknown Source)
> >>> at
> >>> e.java:169)
> >>> at
> >>> at
> >>> at
> >>> va:363)
> >>> at
> >>> va:176)
> >>> Source)
> >>> at
> >>> Ed Merks wrote:
> >>>> Jeroen,
> >>>>> Hi,
> >>>>> java.library.path
> >>>>> What's missing?
> >>>>> Regards,
> >>>>> Jeroen.
> >>>>> Thunderbird? I do!
Re: java.lang.UnsatisfiedLinkError: no localfile_1_0_0 in java.library.path [message #327095 is a reply to message #327092] |
Wed, 09 April 2008 13:33 |
As an experiment, I copied all plugins to my RCP app plugins directory.
Apart from all unwanted items I get, the exception is gone.
Using the jar browser, I found the dll in
org.eclipse.core.filesystem.win32.x86_1.1.0.v20070510.jar
This plugin is available in the app's plugin directory, however it's not
loaded.
And I can't select this plugin to be included as a dependency plugin.
BTW: I'm using a special target platform to build my RCP app.
> Tom
>> Ed Merks wrote:
>>> Jeroen,
>>>> loaded dynamic lib.
>>>> -consolelog
>>>> session; refr
>>>> provides pla
>>>> This library i
>>>> resources plug
>>>> !STACK 0
>>>> at
>>>> at
>>>> ile.java:125)
>>>> at
>>>> va:275)
>>>> at
>>>> at
>>>> anager.java:792)
>>>> at
>>>> anager.java:772)
>>>> at
>>>> ava:663)
>>>> at
>>>> ava:1319)
>>>> at
>>>> 1949)
>>>> at
>>>> 3)
>>>> at
>>>> :363)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> eHost.java:346)
>>>> at
>>>> tBundle.java:260)
>>>> at
>>>> 400)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> eLoader.java:369)
>>>> at
>>>> eLoader.java:357)
>>>> at
>>>> at
>>>> putFactory.java:59)
>>>> at
>>>> nce.java:361)
>>>> at
>>>> e.java:324)
>>>> at
>>>> nce.java:591)
>>>> at
>>>> va:426)
>>>> at
>>>> eference.java:592)
>>>> at
>>>> elper.java:263)
>>>> at
>>>> java:1405)
>>>> at
>>>> r.java:939)
>>>> at
>>>> hreading.java:31)
>>>> at
>>>> at
>>>> va:123)
>>>> at
>>>> at
>>>> at
>>>> sor.java:801)
>>>> at
>>>> 1342)
>>>> at
>>>> hreading.java:31)
>>>> at
>>>> at
>>>> va:123)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> va:289)
>>>> at
>>>> a:461)
>>>> at
>>>> at
>>>> nknown Source)
>>>> at
>>>> e.java:169)
>>>> at
>>>> at
>>>> at
>>>> va:363)
>>>> at
>>>> va:176)
>>>> Source)
>>>> at
>>>> Ed Merks wrote:
>>>>> Jeroen,
>>>>>> Hi,
>>>>>> java.library.path
>>>>>> What's missing?
>>>>>> Regards,
>>>>>> Jeroen.
>>>>>> Thunderbird? I do!
Re: java.lang.UnsatisfiedLinkError: no localfile_1_0_0 in java.library.path [message #327096 is a reply to message #327095] |
Wed, 09 April 2008 13:55 |
One mistake. The file was not in my plugins directory. When I copy it,
the message is gone.
Problem left is finding out how to add this plugin.
> loaded.
>> bundle when started the first time.
>> Tom
>>> Ed Merks wrote:
>>>> Jeroen,
>>>>> loaded dynamic lib.
>>>>> -consolelog
>>>>> session; refr
>>>>> provides pla
>>>>> This library i
>>>>> resources plug
>>>>> !STACK 0
>>>>> java.library.path
>>>>> at
>>>>> at
>>>>> ile.java:125)
>>>>> at
>>>>> va:275)
>>>>> at
>>>>> at
>>>>> anager.java:792)
>>>>> at
>>>>> anager.java:772)
>>>>> at
>>>>> ava:663)
>>>>> at
>>>>> ava:1319)
>>>>> at
>>>>> 1949)
>>>>> at
>>>>> 3)
>>>>> at
>>>>> :363)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> eHost.java:346)
>>>>> at
>>>>> tBundle.java:260)
>>>>> at
>>>>> 400)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> eLoader.java:369)
>>>>> at
>>>>> eLoader.java:357)
>>>>> at
>>>>> at
>>>>> putFactory.java:59)
>>>>> at
>>>>> nce.java:361)
>>>>> at
>>>>> e.java:324)
>>>>> at
>>>>> nce.java:591)
>>>>> at
>>>>> va:426)
>>>>> at
>>>>> eference.java:592)
>>>>> at
>>>>> elper.java:263)
>>>>> at
>>>>> java:1405)
>>>>> at
>>>>> r.java:939)
>>>>> at
>>>>> hreading.java:31)
>>>>> at
>>>>> at
>>>>> va:123)
>>>>> at
>>>>> at
>>>>> at
>>>>> sor.java:801)
>>>>> at
>>>>> 1342)
>>>>> at
>>>>> hreading.java:31)
>>>>> at
>>>>> at
>>>>> va:123)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> va:289)
>>>>> at
>>>>> a:461)
>>>>> at
>>>>> at
>>>>> nknown Source)
>>>>> at
>>>>> e.java:169)
>>>>> at
>>>>> at
>>>>> at
>>>>> va:363)
>>>>> at
>>>>> va:176)
>>>>> Source)
>>>>> at
>>>>> Ed Merks wrote:
>>>>>> Jeroen,
>>>>>> error message like this. Perhaps showing the stack trace will
>>>>>> provide more information that someone might recognize the cause...
>>>>>>> Hi,
>>>>>>> java.library.path
>>>>>>> my console other than my 'own'.
>>>>>>> What's missing?
>>>>>>> Regards,
>>>>>>> Jeroen.
>>>>>>> Thunderbird? I do!
Re: java.lang.UnsatisfiedLinkError: no localfile_1_0_0 in java.library.path [message #327116 is a reply to message #327096] |
Thu, 10 April 2008 12:45 |
Shouldn't this org.eclipse.core.filesystem.win32.x86_1.1.0.v20070510.jar
plugin be deployed to my plugins rcp app directory by default?
If not, how can I do that?
>> directory. Apart from all unwanted items I get, the exception is gone.
>> not loaded.
>>> Tom
>>>> Ed Merks wrote:
>>>>> Jeroen,
>>>>>> than that it's present in almost every crash report of Eclipse as
>>>>>> a loaded dynamic lib.
>>>>>> -consolelog
>>>>>> session; refr
>>>>>> library provides pla
>>>>>> This library i
>>>>>> resources plug
>>>>>> !STACK 0
>>>>>> java.library.path
>>>>>> at
>>>>>> at
>>>>>> ile.java:125)
>>>>>> at
>>>>>> va:275)
>>>>>> at
>>>>>> at
>>>>>> anager.java:792)
>>>>>> at
>>>>>> anager.java:772)
>>>>>> at
>>>>>> ava:663)
>>>>>> at
>>>>>> ava:1319)
>>>>>> at
>>>>>> 1949)
>>>>>> at
>>>>>> 3)
>>>>>> at
>>>>>> :363)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> eHost.java:346)
>>>>>> at
>>>>>> tBundle.java:260)
>>>>>> at
>>>>>> 400)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> eLoader.java:369)
>>>>>> at
>>>>>> eLoader.java:357)
>>>>>> at
>>>>>> at
>>>>>> putFactory.java:59)
>>>>>> at
>>>>>> nce.java:361)
>>>>>> at
>>>>>> e.java:324)
>>>>>> at
>>>>>> nce.java:591)
>>>>>> at
>>>>>> va:426)
>>>>>> at
>>>>>> eference.java:592)
>>>>>> at
>>>>>> elper.java:263)
>>>>>> at
>>>>>> java:1405)
>>>>>> at
>>>>>> r.java:939)
>>>>>> at
>>>>>> hreading.java:31)
>>>>>> at
>>>>>> at
>>>>>> va:123)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> sor.java:801)
>>>>>> at
>>>>>> 1342)
>>>>>> at
>>>>>> hreading.java:31)
>>>>>> at
>>>>>> at
>>>>>> va:123)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> va:289)
>>>>>> at
>>>>>> a:461)
>>>>>> at
>>>>>> at
>>>>>> nknown Source)
>>>>>> at
>>>>>> e.java:169)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> va:363)
>>>>>> at
>>>>>> va:176)
>>>>>> Method)
>>>>>> Source)
>>>>>> Source)
>>>>>> at
>>>>>> Ed Merks wrote:
>>>>>>> Jeroen,
>>>>>>>> Hi,
>>>>>>>> java.library.path
>>>>>>>> What's missing?
>>>>>>>> Regards,
>>>>>>>> Jeroen.
>>>>>>>> Thunderbird? I do!
Current Time: Fri Jan 03 01:58:31 GMT 2025
Powered by FUDForum. Page generated in 0.03523 seconds
