Home » Eclipse Projects » Eclipse Platform » Generic form editor for EMF EObjects
Generic form editor for EMF EObjects [message #327087] Wed, 09 April 2008 10:52 Go to next message
Jonas Helming is currently offline Jonas HelmingFriend
I guess this has been done and answered before, but i was not able to find
sth. helpful.
I would like to build a generic editor for emf models, cause i cannot
hard-code a seperate form for every emf element in my application. That
means the editor has to look into the emf model and create a form for all
the avaiable features.
Also i would like to enhance the emf model with some custom information
about the visualizations of the attributes, for instance to group them on
the editor form.
Maybe someone has a hint how to do this or a link to an example solving
one or both problems.
Thanks for any help!
Jonas
Re: Generic form editor for EMF EObjects [message #327089 is a reply to message #327087] Wed, 09 April 2008 12:24 Go to previous messageGo to next message
--------------070505010503020002070408
Jonas,
It's best to ask EMF questions on the EMF newsgroup, which I've added to
the "to" list of the reply.
Jonas wrote:
> Hello,
> find sth. helpful.
> That means the editor has to look into the emf model and create a form
> for all the avaiable features.
The properties view is like a form. I was experimenting with using data
binding to generate a form using the same information as is used to
generate the properties view.
> information about the visualizations of the attributes, for instance
> to group them on the editor form.
Michael Scharf did something interesting a while back:
< http://scharf.gr/eclipse/eclipsecon2006/Unconventional_but_S imple_Annotations_to_Customize_EMF_Editors/>
> solving one or both problems.
> Jonas
<html>
<head>
http-equiv="Content-Type">
</head>
Jonas,<br>
<br>
to the "to" list of the reply.<br>
<br>
<br>
Jonas wrote:
<blockquote
cite="mid:a0fdfc78bc144e53f8f88633b2798abf$1@www.eclipse.org"
type="cite">Hello,
<br>
find sth. helpful.
<br>
<br>
<br>
</blockquote>
Re: Generic form editor for EMF EObjects [message #327104 is a reply to message #327089] Wed, 09 April 2008 18:29 Go to previous messageGo to next message
Steve Blass is currently offline Steve BlassFriend
Ed Merks wrote:
> Jonas,
> Jonas wrote:
>> Hello,
>> find sth. helpful.
>> Jonas
There's an example of a reflective master/details form editor for emf
models at http://www.conceptualprocessengineering.com/library/
The file you would want to look at is
http://www.conceptualprocessengineering.com/library/gfe01.zi p
It is a bit dated and there are some problems with it - cut/copy/paste
aren't reliable; it should use focus listeners instead of modify
listeners; it only handles text and integer elements; ... But, it does
set up a form editor that provides basic master/details editing for any
EMF model you assign it to edit using the old style file extension
mechanism for assigning editors to file types. You're welcome to it but
caveat implementor.
Steve
yea, I know. I should update it.
Re: Generic form editor for EMF EObjects [message #327112 is a reply to message #327089] Thu, 10 April 2008 07:57 Go to previous messageGo to next message
Roman Porotnikov is currently offline Roman PorotnikovFriend
There is also something from itemis, they blog about it at
http://apps.itemis.de/roller/itemislabkiel/entry/generic_mod elling .
There is a link to a video demonstration, but they say "We're not sure
where exactly we're going to release it".
Roman
Ed Merks wrote:
> Jonas,
> Jonas wrote:
>> Hello,
>> find sth. helpful.
>> Jonas
Re: Generic form editor for EMF EObjects [message #327117 is a reply to message #327112] Thu, 10 April 2008 12:54 Go to previous messageGo to next message
Originally posted by: dennis.huebner.gmail.org
Hi Roman,
the Generic Editor is already in oAW-Repository. There is also a little
example project. It works with EMF2.3 and EMF-Databinding. We will build
a itemis eclipse-oAW distribution where the editor will be included.
Later with oAW5 the editor should be included in official releases.
Dennis.
> Roman
> Ed Merks wrote:
>> Jonas,
>> Jonas wrote:
>>> Hello,
>>> find sth. helpful.
>>> form for all the avaiable features.
>> data binding to generate a form using the same information as is used
>> to generate the properties view.
>>> Jonas
Re: Generic form editor for EMF EObjects [message #327134 is a reply to message #327104] Fri, 11 April 2008 09:21 Go to previous messageGo to next message
Thanks a lot Steve. I wrote you an E-Mail, but I guess the adress on the
page is out-dated:
I downloaded your generic forms editor for EMF, a very good idea.
I would need sth. quite similiar for my application (a university
project). We had a quite similar system running, but we decided to
transfer it into eclipse and further use EMF, so we have to re implement
it. How did you solve the the problem of additional information you need
to visualize the model? Did you use annotations?
Unfortunately it seems that you are not working on this project anymore.
Further i couldnŽt get the code running, i guess it is not compatible to
the new eclipse framework versions. Could you give me any hints to get the
example running?
I also would be interested, why you stopped the work on such an
interesting project or if you could imagine to reboot it (maybe together?).
Thanks for your answer
Jonas
Re: Generic form editor for EMF EObjects [message #327135 is a reply to message #327089] Fri, 11 April 2008 09:24 Go to previous messageGo to next message
Thank you Ed for moving the post and sorry, i am quite new to the
community...
Do you have any idea how to get in contact with michael or which project
he is working on? the presentation looks very promising.
Re: Generic form editor for EMF EObjects [message #327136 is a reply to message #327117] Fri, 11 April 2008 09:29 Go to previous messageGo to next message
Thanks Roman and Dennis. This looks very promising. Do you know if sb. is
already using this editor?
Re: Generic form editor for EMF EObjects [message #327137 is a reply to message #327117] Fri, 11 April 2008 09:37 Go to previous messageGo to next message
Dennis,
could you give me a hint where to find the code in the repo?
jonas
Re: Generic form editor for EMF EObjects [message #327138 is a reply to message #327135] Fri, 11 April 2008 10:31 Go to previous messageGo to next message
--------------040300080608060204060703
Jonas,
There's no problem with posting to a more general newsgroup the first
time. It happens plenty. Eclipse is one big happy family so it's
sometimes hard to find exactly the right place to ask a specific question.
If you don't read the Planet Eclipse blogs, you'll likely be
interested. Someone had a post on topic very similar to your question
yesterday:
http://www.planeteclipse.org/planet/
http://eclipser-blog.blogspot.com/2008/04/automatic-generati on-of-emf-editor-idea.html
Michael has a blog there as well.
http://michaelscharf.blogspot.com/
I sent him a note indicating that you are interested in his work and
asking him to look at this note thread...
> community...
> project he is working on? the presentation looks very promising.
<html>
<head>
</head>
Jonas,<br>
<br>
time.
Re: Generic form editor for EMF EObjects [message #327149 is a reply to message #327135] Fri, 11 April 2008 15:45 Go to previous messageGo to next message
Originally posted by: eclipse-newsgroups.scharf.gr
Hi Jonas,
this project was a typical "Teflon Project"[1].
I put it together in a relatively short time and
it was great do demo. We have also build some
products on top. Unfortunately, my management
did not understand the value of the project
(although I played all the tricks of a Teflon-programmer)
and now is has been degraded from generic solution
for a range of problems to a specific solution
for one particular project.
The sad side of the story is that inside my company
there is the mis-perception that the generic editor is
huge and complicated. And this comes mainly from the
fact that I use EMF and the underlying data model.
And because EMF dragged in a lot of other plugins [2]
at that time, the perception was that my framework
is heavyweight (because the all of emf including
JDT were seen as part of my framework).
Ironically nobody wants to use my "heavy wight" framework,
and therefore many new frameworks were written implementing
their own (incomplete) version of EMF. One of those "lightweight"
UI frameworks that was created is 10 times bigger than my code
(if you don't count EMF as part of the generic editor).
We are still working on the generic editor
as part of the project it has been confined to in the hope
to put it into the light when its time has come....
At the moment we are not working on the UI part of the
framework, but on the infrastructure needed for that
particular project. But in the not to far future we want
to refactor/rewrite the generic UI part. Maybe we join
our forces with the OAW generic editor.
As shown in the presentation, I decided to use annotations
to drive the UI. We call those annotations UIHints, because
they give a hint to the renderer how to display the properties
in the UI. I deliberately chose the term "hint" because the
ui-engine might decide to ignore some hints. It is like
HTML in the old days, where you specified this is a header,
or emphasized and the html browser does the layout for you
(or like LaTex).
This project started 4 years ago, at that time there was
noting like OCL available for EMF. But to do the UI, you
also need validation and some basic form of enable/disable
support for controls. I had written a tiny expression
evaluator based on OQL [3]. With OQL the user can specify
disablement of attributes as well as validation.
Today I'd use CQL [4] or openArchitectureWare Check [5].
I addition, I created my own incarnation of databinding [6],
because it was not available at that time.
Unfortunately, the weakest part of our generic editor is
the engine that interprets the UIHints and turns it into
the UI. It started as a very small set of hints and the
number of hint grew but I did not have time to refactor
the engine, although I have some ideas hoe I'd do it.
I think it would be great if we could put all the different
efforts together and create a solid data-driven UI.
Note: although we use EMF annotations for the UIHints there is
nothing that prevents us from absrtacting this out. All you
need is to get the UI hints for a given element:
UIHint[] HintAdapter.getHints(Object object)
Note 2: one other obvious idea is to extend emfatic [8] to make
the annotations have a Metamodel. Now annotations are free-form.
When you have a metamodel for annotations you can create an
text editor that (using TMF [7]). We did some experiments using
xText [9] to create our own version of emfatic.
I think the biggest contribution I can make is to share my
experience, the good and the bad decisions we made on our
generic editor (I switch here between "my" and "our" framework,
because most of the design and implementation was done by
me with Anton Leherbauer contributing some of the initial
UIHint engine and doing some bug fixing and Richard Memory
working right now on the framework)
Michael
[1] http://ed-merks.blogspot.com/2008/04/teflon-programming.html
[2] https://bugs.eclipse.org/bugs/show_bug.cgi?id=106804
[3] http://en.wikipedia.org/wiki/Object_Query_Language
[4] http://www.eclipse.org/modeling/mdt/?project=ocl#ocl
[5] http://www.eclipse.org/gmt/oaw/doc/4.2/html/contents/core_re ference.html
[6] http://wiki.eclipse.org/index.php/JFace_Data_Binding
[7] http://www.eclipse.org/proposals/tmf/
[8] http://www.eclipse.org/gmt/oaw/doc/4.2/html/contents/using_t he_emfatic_ecore_editor.html
[9] http://www.eclipse.org/gmt/oaw/doc/4.2/html/contents/xtext_r eference.html
> community...
Michael Scharf
Wind River Systems GmbH
Michael (dot) Scharf [at] WindRiver {dot} com
http://www.WindRiver.com
http://MichaelScharf.blogspot.com/
Re: Generic form editor for EMF EObjects [message #327151 is a reply to message #327134] Fri, 11 April 2008 16:55 Go to previous messageGo to next message
comments inline...
> page is out-dated:
Its still there but I don't use it much, I'll go check it though.
> the example running?
You can copy the source files individually into package folders in a new
plugin project you create to get it going in 3.3 or 3.4. Look at the
plugin.xml in the source zip to identify the plugin dependencies you
should add to your new project through the PDE editor. Once it builds
you do need to create a model instance - probably with the wizard in a
stock generated editor - and you have to assign the model instance file
type to the generic editor so it shows up in the "Open-with" menu. I
didn't do anything about visualizing additional information.
Stuff happens.
The OAW editor work Dennis Huebner mentioned in his post sounds like it
is worth a real good look as it is part of a real live ongoing project.
I'm thrilled to see advances being made. I'm stuck on the sidelines for
a while.
> Jonas
Re: Generic form editor for EMF EObjects [message #327154 is a reply to message #327149] Fri, 11 April 2008 17:44 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Hi Michael,
Interesting that you use UIHints. I have been working for a few months on generating web ui's on the
basis of ecore models. I also incorporated the idea of using annotations to hint to the generator
(the templates really, what you call the engine I think) which ui-controls to generate for specific
efeatures. This because the domain model in itself does often not contain enough information to make
sensible choices in the templates.
Earlier this week I created a proposal for generating web apps with ui's on the basis of ecore
models and ui-annotations:
http://wiki.eclipse.org/texo
I posted the proposal on various eclipse newsgroups, hopefully this can become an EMFT project.
Would it be possible/are you interested to share the current set of ui-annotations you have? The
ones I have can be found in the proposal above.
For the rest I am very much in favor for more tooling support for maintaining annotations in a more
structured way in model editors. Like what you tested for generating your own editor.
Another group of people is looking at creating a ui-model which allows you to model ui's in a more
structured way. Afaik the idea is to do as a project this within the eclipse modeling project
(correct Ed?).
gr. Martin
Michael Scharf wrote:
> Hi Jonas,
> (or like LaTex).
> Michael
> [5]
> [8]
> [9]
>> community...
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Generic form editor for EMF EObjects [message #327155 is a reply to message #327154] Fri, 11 April 2008 17:48 Go to previous messageGo to next message
Martin,
Yes, I expect Jim van Dam and Yves Yang to create a project proposal...
Martin Taal wrote:
> Hi Michael,
> on generating web ui's on the basis of ecore models. I also
> ui-controls to generate for specific efeatures. This because the
> make sensible choices in the templates.
> ui's on the basis of ecore models and ui-annotations:
> ui-annotations you have? The ones I have can be found in the proposal
> above.
> maintaining annotations in a more structured way in model editors.
> you to model ui's in a more structured way. Afaik the idea is to do as
> a project this within the eclipse modeling project (correct Ed?).
> gr. Martin
>> Hi Jonas,
>> (or like LaTex).
>> Michael
>> [5]
>> [8]
>> [9]
>>> community...
>>>> added to the "to" list of the reply.
Re: Generic form editor for EMF EObjects [message #327187 is a reply to message #327149] Sun, 13 April 2008 17:19 Go to previous messageGo to next message
Hi Michael,
thank you for your detailed answer. ItŽs more an article then a news group
post. :-)
ThatŽs a sad story of missunderstanding. Do i understand it correct that
the project has never been open source? Is that what you mean with
"putting it into the light"?
> (or like LaTex).
I like the term "UIHints". I my old application we saved the UIHints in
property files, but annotations seem to be more maintainable as the are
integrated into the model. As i understood it the annotations are also
bound to the according feature object?
Are there any problems if you use dynamic instances of emf?
I am not sure if i am going to use databindings. As i understood it the
implementation for EMF are not finished. Can i use databindings together
with commands?
Hmm, i guess it could be hard to consolidate different application
domains. For my application i would say that the number of UIHints can be
quite low. Our focus is not to create very complex UIŽs but to provide
dynamically generated editors for model elements in a unified layout and
look. The meta-model can change over the application life time.
This is how we did it in our old application:
every attribute was described with some basic UIHints like:
-Type: the widget to display and edit the attribute. We had a number of
widgets like link editors or text-areas, which also implemented the
databinding. So they are a little bit more then the eclipse.ui.widgets. Do
you know sth. like this, for example a widget to edit a N:N reference with
add and remove buttons?
-Label
-Tab
-Editable
-Optional
and so on...
Additional every element type had a list of all the displayed attributes
to determine the order of the attributes.
The UI was created on runtime based on this information using a factory
which created the widgets. Then the were put together on a form. Does your
approach work sh. like this?
Definitly!
Sound like a good idea, i will have a look at this.
Re: Generic form editor for EMF EObjects [message #327189 is a reply to message #327187] Sun, 13 April 2008 19:17 Go to previous messageGo to next message
Jonas,
The org.eclipse.emf.databinding.edit plugins available in EMF 2.4 will
make all changes to the model using command and are hence undoable. It
should work well, but if anything isn't, I'll fix the problems promptly.
Jonas wrote:
> Hi Michael,
> group post. :-)
> that the project has never been open source? Is that what you mean
> with "putting it into the light"?
>> (or like LaTex).
> in property files, but annotations seem to be more maintainable as the
> are integrated into the model. As i understood it the annotations are
> also bound to the according feature object?
> the implementation for EMF are not finished. Can i use databindings
> together with commands?
> be quite low. Our focus is not to create very complex UIŽs but to
> provide dynamically generated editors for model elements in a unified
> layout and look. The meta-model can change over the application life
> time.
> of widgets like link editors or text-areas, which also implemented
> the databinding. So they are a little bit more then the
> eclipse.ui.widgets. Do you know sth. like this, for example a widget
> to edit a N:N reference with add and remove buttons?
> -Label -Tab
> -Editable
> -Optional
> and so on...
> attributes to determine the order of the attributes.
> factory which created the widgets. Then the were put together on a
> form. Does your approach work sh. like this?
> Definitly!
Re: Generic form editor for EMF EObjects [message #327221 is a reply to message #327189] Mon, 14 April 2008 12:15 Go to previous messageGo to next message
i ve EMF 2.4 installed, but i couldnŽt find the plugin emf.databindings.
could you tell me where to get it?
Re: Generic form editor for EMF EObjects [message #327223 is a reply to message #327221] Mon, 14 April 2008 12:29 Go to previous messageGo to next message
--------------060308040005000705070103
Jonas,
These should be present...
eclipse/plugins/org.eclipse.emf.databinding.edit_1.0.0.v2008 04012208.jar
eclipse/plugins/org.eclipse.emf.databinding_1.0.0.v200804012 208.jar
Jonas wrote:
> Hi
Re: Generic form editor for EMF EObjects [message #327290 is a reply to message #327223] Tue, 15 April 2008 10:21 Go to previous messageGo to next message
I am sorry but I installed the complete Model and Model Developement from
the ganymede site in ganymede and tried the same in europe, but the
databindings plugins are not there. Do they have an own updat site?
Re: Generic form editor for EMF EObjects [message #327296 is a reply to message #327290] Tue, 15 April 2008 10:48 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
I'm using
http://www.eclipse.org/downloads/download.php?file=/modeling /emf/emf/downloads/drops/2.4.0/S200804012208/emf-sdo-xsd-SDK -2.4.0M6.zip
And the .jars are there. Maybe it's a problem with the update-site?
Tom
Jonas schrieb:
> from the ganymede site in ganymede and tried the same in europe, but the
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Generic form editor for EMF EObjects [message #327303 is a reply to message #327296] Tue, 15 April 2008 12:15 Go to previous messageGo to next message
Thank you that worked for me. But i had to copy the jars manually. Even
with local update site, i couldnŽt install them using the update manager.
Re: Generic form editor for EMF EObjects [message #327307 is a reply to message #327303] Tue, 15 April 2008 12:34 Go to previous messageGo to next message
Nick,
Could you please verify that these things (the two new data binding
plugins and their features) are getting onto the update site and that I
didn't screw something up when I added these new plugins.
> Even with local update site, i couldnŽt install them using the update
> manager.
Re: Generic form editor for EMF EObjects [message #327370 is a reply to message #327307] Wed, 16 April 2008 16:43 Go to previous messageGo to next message
Jonas,
Nick opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=227376 to fix
my oversight that resulted in the features not being include and hence
these plugins not being available with the update manager.
Ed Merks wrote:
> Nick,
> I didn't screw something up when I added these new plugins.
>> manager.
Re: Generic form editor for EMF EObjects [message #327391 is a reply to message #327370] Thu, 17 April 2008 12:38 Go to previous message
cool thanks!
Previous Topic:PlatformUI.RETURN_UNSTARTABLE ??
Next Topic:Empty composite preferred size
Current Time: Thu Dec 26 22:47:46 GMT 2024
Powered by FUDForum. Page generated in 0.04000 seconds
