Re: Conditional Enablement for Handlers on a Workbench Part [message #327075 is a reply to message #327054] |
Tue, 08 April 2008 16:47 |
Stuart Pond wrote:
> Paul,
> Thanks for the quick reply. But that was not my question. I have an RCP
> application that has its own Save Contribution with its own Save Command
> that I want to tie the enablement state to a paticular ViewPart's dirty
> state.
Ah, OK, that will be outside of the framework save lifecycle.
> Should I do this with a property tester? (did this but it only gets fired
> when the activePart changes so it completely misses the dirty state change)
In 3.3 property testers (which aren't listening for anything) are only
updated when some known variable (like the activePart) changes. In 3.4
you can request a property be re-evaluated using IEvaluationService
(when the active part fires a PROP_DIRTY, for example).
> Should I override isEnabled() on my handler?
This will work in 3.3, once your handler has been instantiated ... you
will have to make sure you track the active part, listening for part
property changes like PROP_DIRTY ... and remove yourself as a part
listener on every part lifecycle/close event (IPartListener2).
In 3.4, every framework request to check enabled state calls
setEnabled(*) before calling isEnabled(), which allows you to extract
the active part. Although this might not be that helpful, since you
need to make sure that your handler knows about part closings so it can
remove itself as a listener.
> Should I tell my view to get the saveCommand from the command service and
> tell it to refresh?
This is the hardest to do in 3.3. You might be able to get the command
and call getHandler() on it ... but that would most likely return a
HandlerProxy (internal class) for plugin.xml contributions.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Paul Webster
FUDForum. Page generated in 0.04816 seconds
