Home » Eclipse Projects » Eclipse Platform » org.apache.tools.ant.Task#getProject() returns null in custom ant task when called from within JUnit
org.apache.tools.ant.Task#getProject() returns null in custom ant task when called from within JUnit [message #327035] Mon, 07 April 2008 08:46 Go to next message
Hi all,
im am developing a custom ant task.
I had a problem with getProject() returning null.
After looking at Bugzilla 34466
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=34466) I mananged to get
it work in the exported plug-in.
However when called from within a JUnit plug-in test or a self-hosted
runtime workbench, the problem is still present.
Does anyone have an idea how to solve this?
Lars
Re: org.apache.tools.ant.Task#getProject() returns null in custom ant task when called from within J [message #327126 is a reply to message #327035] Thu, 10 April 2008 15:02 Go to previous messageGo to next message
Hi Lars,
Have you checked out
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/ant_developing.htm
It lays out the best practises for testing custom ant tasks or types.
HTH
Darins
http://runnerwhocodes.blogspot.com
"Lars Heinemann" <Lars.Heinemann@innovations.de> wrote in message
news:ftd53k$du$1@build.eclipse.org...
> Hi all,
> (https://bugs.eclipse.org/bugs/show_bug.cgi?id=34466) I mananged to get it
> Cheers,
> Lars
Re: org.apache.tools.ant.Task#getProject() returns null in custom ant task when called from within J [message #327141 is a reply to message #327126] Fri, 11 April 2008 07:51 Go to previous message
Thanks Darin,
the solution was to exclude the ant-bin folder from the Plug-in runtime
classpath.
Lars
Darin Swanson schrieb:
> Hi Lars,
> HTH
> Darins
>> Hi all,
>> Cheers,
>> Lars
Previous Topic:Dynamic menus
Next Topic:Problem with custom Ant Task inheriting from abstract Task located in different plug-in
Current Time: Wed Apr 16 01:16:08 EDT 2025
Powered by FUDForum. Page generated in 0.03766 seconds
