Home » Eclipse Projects » Eclipse Platform » integrating Team CVS API
Re: integrating Team CVS API [message #327016 is a reply to message #327010] |
Fri, 04 April 2008 18:07 |
Eugene Kuleshov Messages: 504 Registered: July 2009 |
Michael Valenta wrote:
> Yes, you would need to use internals to do this. The other thing that
> is missing is a CVS filesystem abstraction that resides on top of EFS
> or java.io.File. There are currently two implementations of
> ICVSResource: one on top of IResource and one on top of a memory model
> for fetching remote state.
Thanks Michael. I looked at the internal packages, but having troubles
to find relevant API and came up with the following code, but can't
figure out how to get ICVSFolder instance for destFolder. From what you
are saying it sounds like I'd have to implement that interface myself if
I need to use java.io.File or EFS?
String location;
String moduleName;
ICVSRepositoryLocation repository =
CVSRepositoryLocation.fromString(location, false);
ICVSFolder destFolder = ?????;
Session session = new Session(repository, destFolder);
session.open(monitor, false /* read-only */);
try {
Command.LocalOption[] localOptions = new Command.LocalOption[] {
Update.makeTagOption(CVSTag.DEFAULT)
IStatus status = Command.CHECKOUT.execute(session,
Command.NO_GLOBAL_OPTIONS,
localOptions,
new String[] { moduleName },
null, // listener
monitor);
} finally {
session.close();
regards,
Eugene
> Vladimir Grishchenko wrote:
>> I don't think there is a published API but you can probably get some
>> mileage
>> by calling into cvs.core internal packages, however this will not
>> guarantee
>> any kind of compatibility across releases. If you don't get a more
>> specific
>> reply here try asking on the team mailing list. There may be additional
>> difficulties with regards to checking out outside of workspace if you
>> mean
>> just any arbitrary directory that is not under an existent Eclipse
>> project
>> (Eclipse projects can reside outside of workspace directory but they are
>> still logically in the workspace).
>> Cheers,
>> V.
>> "Eugene Kuleshov" <eu@md.pp.ru> wrote in message
>> news:ft3aes$efv$1@build.eclipse.org...
>>> Hi,
>>> I an trying to use Team CVS API to checkout files outside of Eclipse
>>> workspace, but now I am not sure if Team CVS is exposing such API and
>>> wonder if this is even possible. Can someone clarify this or give some
>>> pointers to the code? Basically all I need is to run checkout operation
>>> using given cvs location/tag and target location on local file system
>>> (outside workspace).
>>> Thank you in advance
>>> Eugene
Re: integrating Team CVS API [message #327021 is a reply to message #327016] |
Sat, 05 April 2008 04:34 |
Vladimir Grishchenko Messages: 104 Registered: July 2009 |
Looks like CVSWorkspaceRoot.getCVSFolderFor(IContainer resource) will give
you what you need.
-V.
news:ft5qpl$hh8$1@build.eclipse.org...
>... but can't
> String location;
> String moduleName;
> try {
> localOptions,
> null, // listener
> monitor);
> } finally {
> session.close();
> regards,
> Eugene
Re: integrating Team CVS API [message #327023 is a reply to message #327021] |
Sat, 05 April 2008 20:12 |
> you what you need.
Unfortunately it won't. There is no IContainer neither IResource,
because project does not exist yet when checkout is happening.
regards,
Eugene
>> ... but can't
>> String location;
>> String moduleName;
>> try {
>> localOptions,
>> null, // listener
>> monitor);
>> } finally {
>> session.close();
>> regards,
>> Eugene
Re: integrating Team CVS API [message #327024 is a reply to message #327023] |
Sun, 06 April 2008 03:41 |
This is the thing, a project must exist prior to fetch, if there is none you
can always create one. If you don't need afterwards it you can delete it
after checkout.
I don't think it is easy to implement ICVSResource hierarchy on top of
java.io.File to be able to checkout to any filesystem location. For one, you
need to be able to answer a corresponding IResource from
ICVSResource.getResource(), and if there is no project you will face the
same issue.
news:ft8mfp$kql$1@build.eclipse.org...
give
> > you what you need.
> regards,
> Eugene
> >> ... but can't
if
> >> String location;
> >> String moduleName;
> >> try {
> >> localOptions,
> >> null, // listener
> >> monitor);
> >> } finally {
> >> session.close();
> >> regards,
> >> Eugene
Re: integrating Team CVS API [message #327038 is a reply to message #327016] |
Mon, 07 April 2008 13:20 |
Michael Valenta Messages: 35 Registered: July 2009 |
Member |
Yes, you would need to implement your own ICVSFile and ICVSFolder. Much
of the implementation would be straight forward. The complication is in
the management of the meta-data (i.e. the content that goes into the CVS
folder). For the commands to run efficiently, you cannot simply read and
write meta-data each time it is changed. For instance, for operations
that touch multiple files in the same folder, you would want to load the
meta-data once, keep it in memory while the multiple files are touched
and then write the meta-data to disk when the operation moves on to
another folder.
Michael
> String location;
> String moduleName;
> try {
> localOptions,
> null, // listener
> monitor);
> } finally {
> session.close();
> regards,
> Eugene
>>> mileage
>>> guarantee
>>> specific
>>> mean
>>> project
>>> Cheers,
>>> V.
>>>> Hi,
>>>> Eugene
Re: integrating Team CVS API [message #327046 is a reply to message #327038] |
Mon, 07 April 2008 15:37 |
Thanks Michael.
I've done partial and very naive implementation of that ICVSResource
API that is sufficient for checkout operation. I have to admit that it
was quite strange that metadata files are not handled by CVS code as
other regular files and require reimplementing metadata handling for
each physical system. For instance it is still unclear to me how to
detect that operation moves to another folder?
regards,
Eugene
> Much of the implementation would be straight forward. The complication
> is in the management of the meta-data (i.e. the content that goes into
> the CVS folder). For the commands to run efficiently, you cannot
> simply read and write meta-data each time it is changed. For instance,
> for operations that touch multiple files in the same folder, you would
> want to load the meta-data once, keep it in memory while the multiple
> files are touched and then write the meta-data to disk when the
> operation moves on to another folder.
> Michael
>>> that is missing is a CVS filesystem abstraction that resides on top
>>> of EFS or java.io.File. There are currently two implementations of
>>> model for fetching remote state.
>> troubles to find relevant API and came up with the following code,
>> but can't figure out how to get ICVSFolder instance for destFolder.
>> From what you are saying it sounds like I'd have to implement that
>> interface myself if I need to use java.io.File or EFS?
>> String location;
>> String moduleName;
>> try {
>> localOptions,
>> null, // listener
>> monitor);
>> } finally {
>> session.close();
>> regards,
>> Eugene
>>>> some mileage
>>>> guarantee
>>>> specific
>>>> additional
>>>> you mean
>>>> project
>>>> they are
>>>> Cheers,
>>>> V.
>>>>> Hi,
>>>>> Eclipse
>>>>> some
>>>>> operation
>>>>> Eugene
Re: integrating Team CVS API [message #327070 is a reply to message #327046] |
Tue, 08 April 2008 14:26 |
Member |
Eugene,
I agree that ideally, we would have meta-data management that was
re-usable. However, out current story makes use of the Eclipse Resource
layer (i.e. session properties) as the in memory cache and we right all
the meta-data out at the end of the operation. We have discussed
decoupling this from the resources layer but have never had the time to
pursue it.
Michael
> Thanks Michael.
> regards,
> Eugene
>> Michael
>>> String location;
>>> String moduleName;
>>> try {
>>> localOptions,
>>> null, // listener
>>> monitor);
>>> } finally {
>>> session.close();
>>> } regards,
>>> Eugene
>>>>> some mileage
>>>>> guarantee
>>>>> specific
>>>>> additional
>>>>> you mean
>>>>> project
>>>>> they are
>>>>> Cheers,
>>>>> V.
>>>>>> Hi,
>>>>>> Eclipse
>>>>>> some
>>>>>> operation
>>>>>> Eugene
Current Time: Sun Oct 06 07:20:32 GMT 2024
Powered by FUDForum. Page generated in 0.03633 seconds
