Home » Eclipse Projects » Eclipse Platform » some commands "newbie" questions
some commands "newbie" questions [message #326965] Thu, 03 April 2008 13:43 Go to next message
Originally posted by: tom.eiswind.de
HI I'm just getting started with commands, and I think I want to
refactor our app. But on the second glance I have some questions:
1) Toolbar on a form or section header. What would be a nice way to
contribute there ?
2) Guess I have some generic commands as add, remove edit that I want to
apply in different contexts on different objects.
2a) I have a generic handler that knows how to open entities from my
views from different plugins. Seems to me that this should be possible.
2b) Inside an editor i have different sections with add/edit/remove on
their section toolbar. how can I switch the contexts for the different
sections ?
Hope someone can poitn some things out to me :)
Regards Thomas
Re: some commands "newbie" questions [message #326967 is a reply to message #326965] Thu, 03 April 2008 14:14 Go to previous messageGo to next message
> contribute there ?
If you want to contribute commands there, you can either simply add
CommandContributionItems or if you want extensibility then use
IMenuService to populate/release those contribution manager with some
well known, unique ID.
The command would be generic (your add command) and the contributed
handler would determine how it works in each part.
You can provide a default handler for a command, although I'm not sure
if that's what you are asking. A handler has access to the workbench
window selection using the ExecutionEvent application context (see
HandlerUtil for some helper methods).
> sections ?
you can activate a handler-per-editor relatively easily using the
IHandlerService in your createPartControl(*) or equivalent method.
However you determine which section you are working on, you would have
to tell your handler which one to work on (or activate the appropriate
handler for that section).
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: some commands "newbie" questions [message #326994 is a reply to message #326967] Fri, 04 April 2008 02:23 Go to previous messageGo to next message
Hello Paul,
thanks so far. See some more questions below :)
>> contribute there ?
I guess that means I would have to create the toolbars in an appropriate
way. Can you give me an example how to do it and how the uri would have
to look like ?
Now I have sth like:
public void createSearchToolBar() {
IToolBarManager toolbarManager = searchPersonsForm.getToolBarManager();
toolbarManager.add(searchAction);
toolbarManager.update(true);
searchPersonsForm.setHeadClient(toolbarManager.createControl (searchPersonsForm.getHead()));
How can I give the toolbar an id ?
>> to apply in different contexts on different objects.
Thats what I want.
So do I think. But I wonder how to do the following. I have a generic
handler in my core plugin. Another plugin extends the handler to know
handle its contributed types. it also has a view which gives a new
context that the handler should handle. can i somehow extend the handler
of my core plugin or do i have to dofine a new handler in my extending
plugin that points to the handler in core ?
>> sections ?
so there is no way to set a fine grained context on the sections ? maybe
then i should have different commands and not use the generic ones there.
another thing that came to me:
Guess an editor opens some dialogs that have toolbars, can i have
extensibility there to the same way as mentioned above ?
I d like to use commands because of the ongoing discussion on
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201052
this is what i really need in there. Its not so much about extending
everything, but controlling wehter the user can actually do something
based on his rights...
So long
Thomas
> Later,
> PW
Re: some commands "newbie" questions [message #327014 is a reply to message #326994] Fri, 04 April 2008 13:18 Go to previous messageGo to next message
> to look like ?
So using commands in that toolbar can be as simple as creating a
CommandContributionItem and adding it, similar to adding the searchAction.
If you want to be able to contribute to that toolbar using
org.eclipse.ui.menus (and allow others to do so) you would use something
like:
IMenuService ms
= (IMenuService) getSite().getService(IMenuService.class);
ms.populateContributionManager(toolbarManager,
"toolbar:my.editor.id.search.toolbar");
And when closing:
ms.releaseContributions(toolbarManager);
You have a couple of options (just an aside, a default handler tends to
be used for valid global behaviour: for example, the command that opens
the About dialog uses a default handler since that behaviour doesn't
change).
One option: provide an extendible handler as API. When another plugin
contributes a new view, they can extend your handler and activate it for
their view.
Another option: Provide a handler that is configurable using
IExecutableExtension ... then they can provide the handler in their
plugin.xml and configure it.
You would probably activate/deactivate section handlers each time you
activate a different section within your editor. The other option is to
activate one handler for that command for the editor, and have it work
against the active section.
You can use the IMenuService there as well ... but you must be careful
to release the contribution manager when the dialog closes/is disposed.
Later,
PW
Paul Webster
Contribution on Form toolbar more questions [message #327022 is a reply to message #327014] Sat, 05 April 2008 03:22 Go to previous messageGo to next message
Hi Paul et all,
I tried setting
toolbarManager = (ToolBarManager)searchForm.getToolBarManager();
IMenuService ms = (IMenuService)getSite().getService(IMenuService.class);
"toolbar:de.eiswind.mango.client.searchview.toolbar");
and in plugin.xml:
<menuContribution
locationURI="toolbar:de.eiswind.mango.client.searchview.toolbar ">
<!--menuContribution
locationURI="toolbar:de.eiswind.mango.client.search.ui.Search "-->
<command
commandId="de.eiswind.mango.client.core.command.search"
icon="icons/search.gif"
id="de.eiswind.mango.client.search.search.toolbar"
tooltip="%searchTooltip">
</command>
</menuContribution>
in the view (commented out) it works but it doesnt show up in the form
toolbar. when i put actions in there i have to call update on the
toolbarmanager, can it be ?
And another question about the generic handler: Guess I have the edit
command with the genric handler. I want it to be enabled only when the
handler can handle the current selection (and if theres a selection) Can
How can I ask if theres a workbench selection and can I ask the handler
if he can handle it ?
So long
Thomas
Re: Contribution on Form toolbar more questions [message #327041 is a reply to message #327022] Mon, 07 April 2008 10:38 Go to previous message
There is needed a call to toolBarManager.update(true) after the call to
populateContributionManager(*).
There can be 2 parts to this: an enabledWhen clause in the
org.eclipse.ui.handlers extension point. There you can use core
expressions to check the selection and see if it is valid (see some of
http://wiki.eclipse.org/Command_Core_Expressions and the examples from
http://wiki.eclipse.org/Menu_Contributions )
Later,
PW
Paul Webster
Previous Topic:Why not common distro - All - for eclipse SDKs :
Next Topic:matching org.eclipse.ui.ide actions in activity
Current Time: Tue Nov 04 01:44:32 EST 2025
Powered by FUDForum. Page generated in 0.04631 seconds
