Re: Switch off remembering last opened editor [message #326984 is a reply to message #326964] |
Thu, 03 April 2008 20:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Wishwas wrote:
> Hello,
> I have a problem with the opening of editors. I have two editors. One
> just on just an object while the other is basically an editor which
> shows the differences between two selected objects.
> The problem I have is when I select two objects and open it with the
> Diffing editor, The diffing editor is associated with that object. The
> next time I double click on a single object, It tries to open the
> diffing editor since the last open the diffing editor. I will have to
> again open the actual editor using "open with" context menu. But, I want
> the basic editor to open every time I double click and the diffing
> editor should open only when I seect two objects and use "Open with"
> context menu.
> Can someone let me know if I can switch off Eclipse's feature of
> remembering the lsat opened editor on the object.I guess this could
> solve my problem.
No, there is no way to do it right now. I requested such a feature
almost a year ago, but it has received no attention:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=184747
Perhaps if you add your own comments and/or vote for that bug, it might
get fixed in 3.4.x or 3.5...
Eric
FUDForum. Page generated in 0.03959 seconds
