| Questions about Sections and Forms and how to delegate actions to them [message #326834] |
Tue, 01 April 2008 14:23  |
I've to deal with Section at the moment and have some questions regarding
them.
1. I the screenshot below and at various places in the plug-in manifest
editor you can see actions at the right side of a sections header.
http://www.eclipse.org/articles/Article-Forms33/images/secti on-aligned.png
How can I add the actions to this position?
Can there be delegated from extension points?
2. Within a FormEditors header a toolbar and a menu can be defined:
http://www.eclipse.org/articles/Article-Forms33/images/form- menu.png
Is it possible to delegate actions and menus to this places using
extension points? Until now I delegated every action within my plug-in
using org.eclipse.menus and it would be sad to break this paradigm here.
3. I'm using ColumnLayout in my Section. Inside one of my sections is e
tree viewer that grows while using the editor (adding items). Sadly the
section does not grow with it. It keeps its size it took after
initializing and grows only in width, not in height. Even calling
form.reflow(true) and tree.layout(true) after adding a item to the tree
didnt helped. All I want is the section to grab all place available
vertically until the bottom end of the editor region. A good example is
the 'Required Plug-ins' section in the plug-in manifest editors
'Dependencies' tab.
How can this be done?
I could probably answer all the question myself I knew how to get the
plug-in manifest editors sources. So If you know that answer, please let
me know :)
Thank you!
FUDForum. Page generated in 0.04050 seconds
