Home » Eclipse Projects » Eclipse Platform » How to make one page on a Multi-Page read-only ?
How to make one page on a Multi-Page read-only ? [message #326694] Fri, 28 March 2008 15:37 Go to next message
Originally posted by: marcio.debarros.gmail.com
I have a MultiPage that implements a FormEditor, and it has 4 pages.
Three of these pages are form pages and have sub-sets of the model, and
the last page is a plain text editor, which has the complete model in a
XML format. All changes to the model must be made through one of the
form pages, and once the Save button is pressed, it should update the
XML text. However the users should be able to see the text based page,
but can not type or make changes directly to it.
Any suggestion on how can I do that ?
--MD.
Re: How to make one page on a Multi-Page read-only ? [message #326729 is a reply to message #326694] Mon, 31 March 2008 08:39 Go to previous messageGo to next message
Marcio DeBarros wrote:
It would depend on what class implements that text editor - I would
imagine whatever it is, it has a read-only or editable property that can
be set...
Eric
Re: How to make one page on a Multi-Page read-only ? [message #326752 is a reply to message #326729] Mon, 31 March 2008 11:17 Go to previous messageGo to next message
>> and the last page is a plain text editor, which has the complete model
>> in a XML format. All changes to the model must be made through one of
>> the form pages, and once the Save button is pressed, it should update
>> the XML text. However the users should be able to see the text based
>> page, but can not type or make changes directly to it.
> be set...
> Eric
Hi Eric,
The class is org.eclipse.ui.editors.text.TextEditor, the only two
methods that make a reference to a read-only state are:
isEditorInputReadOnly() and isEditorInputModifiable() inherited from
AbstractTextEditor. I also looked at the IEditorInput hierarchy and
there is nothing there as well. But I am not sure if the EditorInput is
the answer for me, because what I am trying to do is to prevent changes
to be made from that specific page, while the file (EditorInput) can be
modified.
It is like if on the plugin.xml editor you could make and save changes
from to the file from the Extensions tab, but could only see, not even
type on the plugin.xml tab.
Re: How to make one page on a Multi-Page read-only ? [message #326765 is a reply to message #326752] Mon, 31 March 2008 21:56 Go to previous messageGo to next message
>>> Hi,
>>> model in a XML format. All changes to the model must be made through
>>> one of the form pages, and once the Save button is pressed, it should
>>> update the XML text. However the users should be able to see the text
>>> based page, but can not type or make changes directly to it.
>> can be set...
>> Eric
> Hi Eric,
> modified.
Would it be enough for you to subclass TextEditor and override one of
those methods or isEditable() to return false?
It is kind of a brute-force approach, but might be the most
straightforward approach. From looking at the implementations of those
methods, it looks like the other way is to get knee deep into document
providers.
Hope this helps,
Eric
Re: How to make one page on a Multi-Page read-only ? [message #326796 is a reply to message #326765] Tue, 01 April 2008 10:08 Go to previous message
>>>> Hi,
>>>> should update the XML text. However the users should be able to see
>>>> the text based page, but can not type or make changes directly to it.
>>> can be set...
>>> Eric
>> Hi Eric,
>> is the answer for me, because what I am trying to do is to prevent
>> changes to be made from that specific page, while the file
>> (EditorInput) can be modified.
> providers.
> Hope this helps,
> Eric
I took an approach similar do what you suggested by extending TextEditor
and then creating two methods disablePage() and enablePage(), inside
each method is call: getSourceViewer().setEditable(true || false);
Then from the main editor before the text page goes in focus I disable
it, and enable it for all the others.
Thanks for your help Eric.
--Marcio.
Previous Topic:Docs for getting started with org.eclipse.ui.menus / handlers ?
Next Topic:executing org.eclipse.ant.core.antRunner with or without shell
Current Time: Wed Oct 15 16:44:07 EDT 2025
Powered by FUDForum. Page generated in 0.04286 seconds
