Home » Eclipse Projects » Eclipse Platform » Tooltips possible for EMF objects in properties view?
Tooltips possible for EMF objects in properties view? [message #326643] Thu, 27 March 2008 07:29 Go to next message
I have an RCP application which has a properties view that displays properties of EMF model objects.
Is it possible to set tooltips on the properties view? The EMF edit code generates a
PropertySheetPage and I would like so that when a user hovers over a particular property it would
display the value in a tooltip. Also is it be possible for the EMF generated item provider property
descriptors to provide the text for the tooltip?
I am using Eclipse 3.2.2 and EMF 2.2
Many thanks,
Conor
Re: Tooltips possible for EMF objects in properties view? [message #326647 is a reply to message #326643] Thu, 27 March 2008 08:43 Go to previous messageGo to next message
I think the generated viewers are using the "old" style ITable*
interface which doesn't support Tooltips. You'll need to switch the
using ColumnLabelProviders new to JFace 3.3.
I think there was a discussion lately on the emf-newsgroup talking about
ColumnLabelProvider. I think the author managed somehow to do this and
filed a bug where the code is attached to.
Tom
Conor O'Mahony schrieb:
> generates a PropertySheetPage and I would like so that when a user
> hovers over a particular property it would display the value in a
> property descriptors to provide the text for the tooltip?
> Many thanks,
> Conor
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Tooltips possible for EMF objects in properties view? [message #326648 is a reply to message #326643] Thu, 27 March 2008 08:45 Go to previous message
Conor,
Something people often don't notice is that when you select a property
the status line at the bottom of the Eclipse window shows a
description. I imagine that same description text could be used to show
hover help, but I don't think the properties view does that by default
and I'm not sure how you'd need to specialize it in order to add such
support...
Conor O'Mahony wrote:
> code generates a PropertySheetPage and I would like so that when a
> user hovers over a particular property it would display the value in a
> Many thanks,
> Conor
Previous Topic:JFace Treeviewer refresh collapses the tree nodes
Next Topic:Dynamic menu contribution to view toolbar does not work?
Current Time: Fri Apr 25 01:43:58 EDT 2025
Powered by FUDForum. Page generated in 0.02971 seconds
