Re: Tooltips possible for EMF objects in properties view? [message #326648 is a reply to message #326643] |
Thu, 27 March 2008 12:45 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Conor,
Something people often don't notice is that when you select a property
the status line at the bottom of the Eclipse window shows a
description. I imagine that same description text could be used to show
hover help, but I don't think the properties view does that by default
and I'm not sure how you'd need to specialize it in order to add such
support...
Conor O'Mahony wrote:
> I have an RCP application which has a properties view that displays
> properties of EMF model objects.
> Is it possible to set tooltips on the properties view? The EMF edit
> code generates a PropertySheetPage and I would like so that when a
> user hovers over a particular property it would display the value in a
> tooltip. Also is it be possible for the EMF generated item provider
> property descriptors to provide the text for the tooltip?
> I am using Eclipse 3.2.2 and EMF 2.2
> Many thanks,
> Conor
FUDForum. Page generated in 0.03328 seconds
