| Default package always visible [message #326633] |
Wed, 26 March 2008 15:38  |
in my Java projects the (default package) is always visible. A collegue of
mine does not see this empty (and in my opinion useless) package in his
projects.
Is there a way to remove this (once I have real packages created)?
Best regards, Lars
| Re: Default package always visible [message #326685 is a reply to message #326672] |
Fri, 28 March 2008 09:52   |
Walter Harley wrote:
> "Lars Vogel" <Lars.Vogel@gmail.com> wrote in message
> news:fse8n0$3dr$1@build.eclipse.org...
>> projects.
> Seems like some setting in your workspace must have gotten changed. Does
> this happen in newly created workspaces?
> I notice there's a setting about folding empty packages in Package Explorer,
> in Prefs -> Java -> Appearance. It doesn't seem to change anything, but
> there's a note at the bottom of the dialog that says it only takes effect
> "on new perspectives", which seems cryptic (i.e., I know how to close and
> open views, but I don't know how to create a "new" perspective). Perhaps
> changing that and then restarting Eclipse would work?
No, restarting Eclipse won't cause the Perspective to reset. You need to
close the Perspective and re-open it (or maybe Window > Reset
Perspective might work, but I doubt it).
Hope this helps,
Eric
| Re: Default package always visible [message #326773 is a reply to message #326633] |
Tue, 01 April 2008 03:46  |
Lars Vogel wrote:
> projects.
Sure. Simply enable the 'Empty parent packages' filter (via Package
Explorer view menu > Filters...)
Dani
> Best regards, Lars
FUDForum. Page generated in 0.27977 seconds
