Home » Eclipse Projects » Eclipse Platform » FileInputStream and IFile
FileInputStream and IFile [message #326570] Tue, 25 March 2008 09:26 Go to next message
Originally posted by: alexjaquet.gmail.com
I'm looking for a way to create FileInputStream within an IFile,
i've tryed to create it with
private void initializeContents(IFile file) {
try {
FileInputStream fis = new
FileInputStream(file.getFullPath().toString());
BufferedReader myInput = new BufferedReader (new InputStreamReader(fis));
String thisLine = null;
StringBuffer buffer = new StringBuffer();
while ((thisLine = myInput.readLine()) != null) {
System.out.println(thisLine);
buffer.append(thisLine);
myInput.close();
setContents(buffer.toString());
} catch (Exception e) {
e.printStackTrace();
but the file.getFullPath doesn't give the absolut full path
How can I deal with it
Alexandre
Re: FileInputStream and IFile [message #326571 is a reply to message #326570] Tue, 25 March 2008 09:34 Go to previous messageGo to next message
the method System.out.println("Project path " +
ResourcesPlugin.getWorkspace().getRoot().getLocation().toOSS tring() );
return my the junit-workspace
Re: FileInputStream and IFile [message #326572 is a reply to message #326570] Tue, 25 March 2008 09:42 Go to previous messageGo to next message
Originally posted by: valere.fedronic.ext.streamezzo.com
Why don't you use the getContent() method?
InputStream fis = file.getContents();
Valère.
Alexandre Jaquet a écrit :
> try {
> myInput.close();
> Thanks
> Alexandre
Re: FileInputStream and IFile [message #326573 is a reply to message #326571] Tue, 25 March 2008 09:47 Go to previous messageGo to next message
finally founded FileInputStream fis = new
FileInputStream(file.getLocation().toString());
Re: FileInputStream and IFile [message #326574 is a reply to message #326573] Tue, 25 March 2008 10:48 Go to previous messageGo to next message
Alexandre,
This is still a bad idea. Why not follow the other advice that was
given? Why is it so important to access the underlying file directly?
Given that EFS supports non-file-based locations, your approach here
isn't fully general...
Re: FileInputStream and IFile [message #326575 is a reply to message #326574] Tue, 25 March 2008 11:17 Go to previous message
Ok thanks for your suggestion I will change that :)
Alexandre
Previous Topic:CompareEditor ; StructureInputPane
Next Topic:[DataBinding] Date conversion
Current Time: Mon Sep 15 23:13:35 EDT 2025
Powered by FUDForum. Page generated in 0.25964 seconds
