FileInputStream and IFile [message #326570] |
Tue, 25 March 2008 13:26 |
Originally posted by: alexjaquet.gmail.com
I'm looking for a way to create FileInputStream within an IFile,
i've tryed to create it with
private void initializeContents(IFile file) {
try {
FileInputStream fis = new
FileInputStream(file.getFullPath().toString());
BufferedReader myInput = new BufferedReader (new InputStreamReader(fis));
String thisLine = null;
StringBuffer buffer = new StringBuffer();
while ((thisLine = myInput.readLine()) != null) {
System.out.println(thisLine);
buffer.append(thisLine);
myInput.close();
setContents(buffer.toString());
} catch (Exception e) {
e.printStackTrace();
but the file.getFullPath doesn't give the absolut full path
How can I deal with it
Alexandre
Re: FileInputStream and IFile [message #326571 is a reply to message #326570] |
Tue, 25 March 2008 13:34 |
the method System.out.println("Project path " +
ResourcesPlugin.getWorkspace().getRoot().getLocation().toOSS tring() );
return my the junit-workspace
Re: FileInputStream and IFile [message #326572 is a reply to message #326570] |
Tue, 25 March 2008 13:42 |
Originally posted by: valere.fedronic.ext.streamezzo.com
Why don't you use the getContent() method?
InputStream fis = file.getContents();
Valère.
Alexandre Jaquet a écrit :
> try {
> myInput.close();
> Thanks
> Alexandre
Re: FileInputStream and IFile [message #326574 is a reply to message #326573] |
Tue, 25 March 2008 14:48 |
Alexandre,
This is still a bad idea. Why not follow the other advice that was
given? Why is it so important to access the underlying file directly?
Given that EFS supports non-file-based locations, your approach here
isn't fully general...
Alexandre Jaquet wrote:
> finally founded FileInputStream fis = new
> FileInputStream(file.getLocation().toString());
FUDForum. Page generated in 0.03419 seconds
