Home » Eclipse Projects » Eclipse Platform » "org.eclipse.ui.examples.navigator"'s code not executing at all, what's wrong?
"org.eclipse.ui.examples.navigator"'s code not executing at all, what's wrong? [message #326508] Fri, 21 March 2008 08:21
Olivier Allard is currently offline Olivier AllardFriend
org.eclipse.ui.examples.navigator doesn't seem to execute right in my
workspace.
I'm not sure what it is suppose to really do but when I've put breakpoints
in the code, it stops nowhere, neither in the ContentProvider nor in the
LabelProvider. In fact I've put breakpoint in every method of every file
of the example, still no hit.
The code seems useless, and the result shown in the generated view seems
only inherited from the common navigator's default behaviour and the
actions defined in the plugin.xml.
Do you know about this problem, or any related one?
Would you know another example from the same Viewer or another similar
viewer?
Thanks to all.
PS.:
I think it might be a compatibility problem with the version of eclipse
I'm using:
When I downloaded org.eclipse.ui.examples.navigator from CVS I tried to
get the one compatible with the 3.3.2 eclipse version I'm using, but there
was no such version, so I got the one from HEAD...
Previous Topic:relative path inside a plugin
Next Topic:MarkerResolutionSelectionDialog
Current Time: Wed Jan 15 13:09:58 GMT 2025
Powered by FUDForum. Page generated in 0.03180 seconds
