Minimal set of plug-ins for InfoCenter [message #326374] |
Tue, 18 March 2008 10:46 |
Roger Villars Messages: 57 Registered: July 2009 |
Member |
Hi.
The InfoCenter help says:
[Optional] Installing a minimal set of plug-ins
The infocenter does not require the entire Eclipse Platform package. It
is possible to run an infocenter with the following plug-ins (located in
the eclipse\plugins directory):
org.apache.lucene
org.eclipse.core.runtime
org.eclipse.help
org.eclipse.help.appserver
org.eclipse.help.base
org.eclipse.help.webapp
org.eclipse.osgi
org.eclipse.tomcat
org.eclipse.update.configurator
I tried to start such a configuration with the following command:
java -classpath
d:\myApp\eclipse\plugins\org.eclipse.help.base_[version].jar
org.eclipse.help.standalone.Infocenter -command start -eclipsehome
d:\myApp\eclipse -port 8081 -noexec
But I got the following error:
java.lang.Exception: Plugins directory
C:\Users\rovi.MIMACOM\Desktop\InfoCenter\.\plugins does not contain
valid startup jar. Pass a correct -eclipsehome option
org.eclipse.help.internal.standalone.Eclipse.getStartupJar(E clipse.java:182)
org.eclipse.help.internal.standalone.Eclipse.prepareJavaComm and(Eclipse.java:76)
org.eclipse.help.internal.standalone.Eclipse.prepareCommand( Eclipse.java:48)
org.eclipse.help.internal.standalone.Eclipse.run(Eclipse.jav a:87)
Starting the InfoCenter with the whole Platform Runtime Binary works but
that's about 40MB.
It seems that the InfoCenter help isn't up to date anymore. Does anybody
know the current minimal needed plugin set for the InfoCenter for
eclipse 3.3?
Roger
FUDForum. Page generated in 0.02731 seconds
