Re: workspace.findFilesForLocation ? [message #326364 is a reply to message #326363] |
Mon, 17 March 2008 21:14 |
John,
It means that a path a/b will be treated as /a/b (or as c:/a/b on
windows). You could use an IResourceVisitor if you want to visit all
resource that match a particular path pattern. Of course a visitor and
this method only search the workspace itself, not your whole file system.
John J Barton wrote:
> I need to find files by filename, eg given "foo.java" I want all files
> in the workspace that have <path>/foo.java.
> This looks hopeful:
> public IFile[] findFilesForLocation(IPath location)
> Returns the handles of all files that are mapped to the given path in
> the local file system. Returns an empty array if there are none. The
> path should be absolute; a relative path will be treated as absolute.
> The path segments need not be valid names. The resulting files may not
> currently exist.
> But it does not work, and the phrase "relative path will be treated as
> absolute" is not at all helpful. What does that mean? "Apples will be
> treated as oranges": do I get orange juice or apple juice?
> If this function does not lookup files like I want, can anyone suggest
> a function that might to it? Otherwise I have to sweep the workstation
> for file names and create/maintain a table I guess.
> John.
FUDForum. Page generated in 0.03364 seconds
