Re: Synchronously delete project [message #326358 is a reply to message #326354] |
Mon, 17 March 2008 16:51 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Marko,
You're sure the teardown didn't fail? I think delete should be
synchronous...
Marko T. wrote:
> Hello folks,
> during running a JUnit Test (where I create test projects to work on
> during the tests) I am getting a ResourceException that a project
> already exists because the deletion is not finished yet from the last
> tearDown() method invocation.
> Is the IResource.delete method returning after the resource (and its
> children) are deleted or is it deleting the IResource asynchronously
> in a seperate Thread?
> If it is done in another thread how can I know when and if the
> resource is really deleted?
Re: Synchronously delete project [message #326360 is a reply to message #326354] |
Mon, 17 March 2008 18:40 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: wharley.bea.com
"Marko T." <Marko.Tomljenovic@de.bosch.com> wrote in message
news:985be4ba3ada943639531db0670db1f2$1@www.eclipse.org...
> Hello folks,
> during the tests) I am getting a ResourceException that a project already
> exists because the deletion is not finished yet from the last tearDown()
> method invocation.
Hi, Marko. I've seen that happen quite a lot. I finally gave up trying to
figure it out, and just tweaked my test code so that every project gets a
unique name (based on incrementing a counter, e.g., TestProject0001,
TestProject0002...).
Re: Synchronously delete project [message #326361 is a reply to message #326360] |
Mon, 17 March 2008 19:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------010903030104010002060604
Walter,
I wonder if there are underlying OS file system delays involved...
>> Hello folks,
>> method invocation.
<html>
<head>
</head>
Walter,<br>
<br>
I wonder if there are underlying OS file system delays involved...<br>
<br>
<br>
<blockquote cite="mid:frmduc$vu7$1@build.eclipse.org" type="cite">
<pre wrap="">"Marko T." <a class="moz-txt-link-rfc2396E" href="mailto:Marko.Tomljenovic@de.bosch.com"><Marko.Tomljenovic@de.bosch.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:985be4ba3ada943639531db0670db1f2$1@www.eclipse.org">news:985be4ba3ada943639531db0670db1f2$1@www.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hello folks,
method invocation.
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------010903030104010002060604--
FUDForum. Page generated in 0.04461 seconds
