Home » Eclipse Projects » Eclipse Platform » Debugging an Ant task with Eclipse 3.4
Debugging an Ant task with Eclipse 3.4 [message #326317] Fri, 14 March 2008 10:58
Hi All,
To debug an Ant task in Eclipse 3.2, I had the following setup:
The plugin.xml defined the Task
<antTask
library="%ANT_LIBRARY"
name="%ANT_TASK_NAME"
uri="%ANT_TASK_NAMESPACE"
class="my.ant.tasks.MyTask">
</antTask>
The plugin.properties file defined the keys. The libary was set to point
to the location of the jar:
ANT_LIBRARY = runtime/myplugin-ant.jar
To debug the application it was sufficient to change the library
location and point to the bin folder:
ANT_LIBRARY = /bin-ant
The location of the /bin-ant folder showed up in classpath if running
the task in the same JRE as the Workspace. Any changes made to the task
were available without restarting the runtime workspace.
In Eclipse 3.4 the above setup doesn't work anymore. Although the
location of the /bin-ant folder still shows up in the classpath, the
task is not found. It works if I create the jar (myplugin-ant.jar).
But this setup is very time consuming. Every time I make a change in the
task I have to close the runtime workspace, delete and recreate the jar
(myplugin-ant.jar) and restart the runtime workspace.
There must be a simpler process of debugging a task.
Anyone knows it ?
Previous Topic:How to detect when Eclipse is not the foreground application?
Next Topic:Cannot find color setting for search hints
Current Time: Thu Oct 23 12:46:13 EDT 2025
Powered by FUDForum. Page generated in 0.06672 seconds
