Re: Support for Multiple Linked files. [message #326278 is a reply to message #326250] |
Thu, 13 March 2008 15:11 |
Mark Espiritu wrote:
> Hi guys,
> Is there a plan to support multiple files if you just want to link to them?
> Instead of have to do this one by one. (File->New->Advanced->Link to File
> System)
Other than linking to a directory instead of a file, I'm not sure what
you mean.
In any case, you can always file an enhancement request in Bugzilla -
http://bugs.eclipse.org/bugs
Eric
Re: Support for Multiple Linked files. [message #326320 is a reply to message #326295] |
Fri, 14 March 2008 18:25 |
> Hi Eric,
> Thanks for the reply.
> Sorry for the vague description. Let me try to clarify. The dialog that pops
> up after hitting the browse button does not seem to allow multiple
> selection.
> It would be very convenient to be able to select multiple files that you
> want to link to instead of having to repeat the prcedure for each one.
> What do you think?
It won't really work, because when you create a linked resource it is
assigned a "logical" name (that you specify) that is used to refer to it
in the project/workspace. If multiple selection was allowed, the UI
would get complex because you'd have to have a way to specify the
logical names for each of them.
Eric
Re: Support for Multiple Linked files. [message #326713 is a reply to message #326344] |
Mon, 31 March 2008 03:10 |
Originally posted by: rapha.d.gmx.de
Hi Mark,
I had pretty much the same problem. In the beginning I was thinking
about reusing the existing 'Import from Filesystem' dialog. But what we
do right now is linking the whole folder and using WorkingSets to
fianlly select the files we want to see.
Best,
Raphael
Mark Espiritu schrieb:
> Hi Eric,
> I was thinking that if multiple files are selected, that we would just use
> the target filenames as the logical names.
> Anyway, I'm thinking now if my suggestion doesn't cover all cases (like you
> mentioned) and/or if we we really need to cover those cases.
> The real difficulty we are encountering is just the sheer number of linked
> files we have to individually link to by hand.
> Perhaps the community can give suggestions?
> Thanks!
> MarkE
> "Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
> news:frefva$ift$1@build.eclipse.org...
>>> Hi Eric,
>>> pops up after hitting the browse button does not seem to allow multiple
>>> selection.
>>> What do you think?
>> in the project/workspace. If multiple selection was allowed, the UI would
>> get complex because you'd have to have a way to specify the logical names
>> for each of them.
>> Eric
FUDForum. Page generated in 0.03937 seconds
