Home » Eclipse Projects » Eclipse Platform » EFS question ...
Re: EFS question ... [message #326236 is a reply to message #326232] |
Wed, 12 March 2008 14:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Kar,
I'm not sure this is entirely avoidable. Eclipse does need to know the
time stamp for each resource the first time so that it can properly do a
refresh should the contents of the tree change outside the control of
the IResource APIs. What specifically is driving the full walk. Is it
indeed this need for an initial sync? I assume it's not actually
loading files but just needs to understand the full folder structure.
If that indeed is taking an unusably long time, you probably need to
rethink your design where the user needs to take explicit actions to
bring folders into view...
KarSc wrote:
> Hi all, hope this is the right forum to ask questions about EFS .
> I'm trying to build an example that with the EFS helps will make me build a
> view with a representation of what is contained in my DB .
> I did actually manage to do it but there is something that I don't not
> really like .
> When I start my test it starts to ask information about the whole tree - the
> problem is that this operation can take a long time if the DB contains more
> than a 1000 object ..
> Is there a way to (for example) just read the information about the first
> "folder" and only once it get expanded read it . I do understand that
> eclipse must probably cache information about name and structure . but this
> really make totally not usable .
> Thanks
> Kar
Re: EFS question ... [message #326240 is a reply to message #326239] |
Wed, 12 March 2008 16:37 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------040202050005050507070208
Kar,
This looks like the right way. How are you creating the file store
instance that you pass to the editor?
KarSc wrote:
> Hi Ed and thanks ...
> in the meantime I did actually create a simple treeview with a basic with
> viewer.setLabelProvider(new WorkbenchLabelProvider());
> viewer.setContentProvider(new BaseWorkbenchContentProvider());
> so I get back my tree for free (no icon no anything but it's a starting
> point) and items are only loaded when I do expand the folder.
> The trouble is ... what shall I do to be able to open an editor on the item
> this was free when a linked the "dbfilesystem" to the resource view ...
> What shall I do now?
> I have tried using what follows
> IEditorDescriptor desc2 =
> PlatformUI.getWorkbench().getEditorRegistry().getDefaultEdit or(fileStore.getName());
> try
> page.openEditor(new FileStoreEditorInput(fileStore), desc2.getId());
> catch (PartInitException e)
> // TODO Auto-generated catch block
> e.printStackTrace();
> but I don't get anything ...
> can u point me in the right direction or what is the class of the navigator
> view so I could probably check what does it do (bear in mind that I know
> very little of EFS and I haven't done any cache of the db file locally, but
> just implemented the get input/output stream on the filestore)
> thanks
> Kar
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:fr8pgc$464$1@build.eclipse.org...
>> Kar,
>> refresh should the contents of the tree change outside the control of the
>> IResource APIs. What specifically is driving the full walk. Is it indeed
>> this need for an initial sync? I assume it's not actually loading files
>> but just needs to understand the full folder structure. If that indeed is
>> taking an unusably long time, you probably need to rethink your design
>> where the user needs to take explicit actions to bring folders into
>> view...
>>> a view with a representation of what is contained in my DB .
>>> really like .
>>> the problem is that this operation can take a long time if the DB
>>> contains more than a 1000 object ..
>>> this really make totally not usable .
>>> Thanks
>>> Kar
<html>
<head>
</head>
Kar,<br>
<br>
instance that you pass to the editor?<br>
<br>
<br>
KarSc wrote:
<blockquote cite="mid:fr8vp8$9na$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed and thanks ...
try
thanks
Kar
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fr8pgc$464$1@build.eclipse.org">news:fr8pgc$464$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Kar,
view...
KarSc wrote:
</pre>
<pre wrap="">Hi all, hope this is the right forum to ask questions about EFS .
really like .
Kar
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------040202050005050507070208--
Re: EFS question ... [message #326269 is a reply to message #326257] |
Thu, 13 March 2008 12:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Kar,
Not all editors support the different input types. :-( Use the
debugger to see what the structured text editor is doing with its input.
KarSc wrote:
> viewer.setInput(EFS.getFileSystem("eom").getStore(new Path("/")));
> and on the double click on the tree item i'm just opening the editor with
> IDE.openEditorOnFileStore(page, fileStore);
> i did actually discovered that the problem is different ...
> i cannot open only xml file ... follows the exception ....
> thanks
> kar
> org.eclipse.ui.PartInitException: Editor could not be initialized.
> at
> org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3028)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3039)
> at
> org.eclipse.wst.sse.ui.StructuredTextEditor.init(StructuredT extEditor.java:2617)
> at
> org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:186)
> at
> org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:160)
> at
> org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.addSourcePage(XMLMultiPageEditorPart.java:378)
> at
> org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.createPages(XMLMultiPageEditorPart.java:554)
> at
> org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:283)
> at
> org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
> at
> org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
> at
> org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
> at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
> at
> org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
> at
> org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
> at
> org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
> at
> org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
> at
> org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
> at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
> at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
> at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
> at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
> at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
> at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
> at
> org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
> at
> org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
> at
> org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
> at
> org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
> at
> org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
> at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
> at
> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2737)
> at
> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
> at org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
> at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2557)
> at testefs.views.SampleView$4$1.run(SampleView.java:399)
> news:fr90rj$ihq$1@build.eclipse.org...
> Kar,
> This looks like the right way. How are you creating the file store instance
> try
> thanks
> Kar
> Kar,
> view...
> really like .
> Thanks
> Kar
Re: EFS question ... [message #326271 is a reply to message #326260] |
Thu, 13 March 2008 12:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------060104060402080606050700
Kar,
In that case it's using an IFile and for sure the editor supports that.
KarSc wrote:
> The weird thing is that ... if I do open the file from the mounted EFS (from
> resource view) - it works fine ...
> or at least I can able to open the file using the xml editor (but when I
> save it the document goes in out of sync ... but it has been saved correctly
> ... just pressing F5 I get the editor back ...)
> this whole thing is driving me crazy ...
> hope u can help me
> Thanks
> Kar
> "KarSc" <carmeloscala@hotmail.com> wrote in message
> news:fraste$44k$1@build.eclipse.org...
>> thanks
>> kar
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Kar,
>> item
>> try
>> navigator
>> but
>> thanks
>> Kar
>> Kar,
>> view...
>> really like .
>> Thanks
>> Kar
<html>
<head>
</head>
Kar,<br>
<br>
In that case it's using an IFile and for sure the editor supports that.<br>
<br>
<br>
KarSc wrote:
<blockquote cite="mid:frau4f$m4n$1@build.eclipse.org" type="cite">
<pre wrap="">The weird thing is that ... if I do open the file from the mounted EFS (from
.... just pressing F5 I get the editor back ...)
hope u can help me
Kar
"KarSc" <a class="moz-txt-link-rfc2396E" href="mailto:carmeloscala@hotmail.com"><carmeloscala@hotmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fraste$44k$1@build.eclipse.org">news:fraste$44k$1@build.eclipse.org</a>...
</pre>
<pre wrap="">viewer.setInput(EFS.getFileSystem("eom").getStore(new Path("/")));
thanks
kar
<a class="moz-txt-link-freetext" href="news:fr90rj$ihq$1@build.eclipse.org">news:fr90rj$ihq$1@build.eclipse.org</a>...
Kar,
item
try
navigator
but
thanks
Kar
Kar,
view...
really like .
Kar
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------060104060402080606050700--
Re: EFS question ... [message #326272 is a reply to message #326263] |
Thu, 13 March 2008 12:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------080101090106060009070802
Kar,
It kind of circles back to your original problem. To make it an IFile,
you need to use EFS as the backing for a view on your database. Maybe
ask the WTP newsgroup about support for different types of input (if
debugging the stack trace doesn't make that clear by inspection).
KarSc wrote:
> checking the ResourceNavigotor I can see that it will actually work on a
> IFile ...
> still what shall I do to obtain an IFile from a filestore :-S
> Kar
>> thanks
>> kar
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Kar,
>> item
>> try
>> navigator
>> but
>> thanks
>> Kar
>> Kar,
>> view...
>> really like .
>> Thanks
>> Kar
<html>
<head>
</head>
Kar,<br>
<br>
debugging the stack trace doesn't make that clear by inspection).<br>
<br>
<br>
KarSc wrote:
<blockquote cite="mid:frb1l9$a1u$1@build.eclipse.org" type="cite">
<pre wrap="">checking the ResourceNavigotor I can see that it will actually work on a
IFile ...
Kar
</pre>
thanks
kar
Kar,
item
try
navigator
but
thanks
Kar
Kar,
view...
really like .
Kar
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------080101090106060009070802--
Current Time: Sat Aug 24 00:43:25 GMT 2024
Powered by FUDForum. Page generated in 0.04575 seconds
