Re: ReqIF Purpose of SpecHierarchy.EditableAtts [message #1696809 is a reply to message #1696744] |
Thu, 28 May 2015 16:32 |
Hi Ratimir,
> I didn't find any element in the reqif schema to accommodate for any values related to these editableAtts, or even an example.
You find them in the Properties View. On the bottom are two tabs, with "Standard Attributes" being the default. Select "All Attributes" to see it.
> However, where would the values be stored in the reqif file, if those values were actually set?
The Spec has a description of the mapping from model to Persistance. Now that you know where to set it, you can try it out. .-)
> I'm wondering about the meaning of the editableAtts Association of a SpecHierarchy.
ReqIF is intended as a transport format, but we use it as a data model. Of course we could just use the flag to manage the read-only status of attributes, but that would not be very useful in itself. Therefore, this attribute is not used for anything right now, just carried through.
Best,
- Michael
FUDForum. Page generated in 0.02605 seconds
