Home » Eclipse Projects » Eclipse Platform » TitleAreaDialog message is cut off if it is longer than 2 lines
TitleAreaDialog message is cut off if it is longer than 2 lines [message #326189] Mon, 10 March 2008 23:59
Eclipse User is currently offline Eclipse UserFriend
It seems TitleAreaDialog limits the title message area to be 2 lines so
that if the message is longer, it would be cut off. Is this working as
designed? Is it possible to dynamically increase the dialog's width if
the message is longer than 2 lines? Or any other workaround?
Janice.
Previous Topic:Menu label problems (seeing % names)
Next Topic:Chat within Eclipse
Current Time: Sat Nov 09 03:37:43 GMT 2024
Powered by FUDForum. Page generated in 0.03492 seconds
