Home » Eclipse Projects » Eclipse Platform » Showing deleted file from local history
Showing deleted file from local history [message #326166] Mon, 10 March 2008 09:16 Go to next message
Originally posted by: chandra.mayamuthu.gmail.com
Hi All,
I need to show the deleted files from local history after deleting the
file physically in the file system.
I have RCP application, in which I will be doing the following,
1. have some list of files in the project.
2. close the workbench
3. delete some of the files externally (in file system)
4. re-launch the application,
5. the deleted files should be restored from local history
Please guide me to restore the deleted files programmatically from local
history.
Chandra M
Re: Showing deleted file from local history [message #326172 is a reply to message #326166] Mon, 10 March 2008 12:38 Go to previous message
Chandra,
From what I understand about this, only by using the Resource APIs to
modify (delete/write) a resource are the old contents backed up in the
local history. If you delete underlying resource directly from the file
system I don't think there will be a backup copy of it anywhere.
Chandra wrote:
> Hi All,
> the file physically in the file system. I have RCP application, in
> local history.
> Chandra M
Previous Topic:Highlighting related terms in a text editor
Next Topic:how to create a master details block in an editor
Current Time: Thu Aug 29 12:39:05 GMT 2024
Powered by FUDForum. Page generated in 0.02708 seconds
