Home » Eclipse Projects » Eclipse Platform » StructuredTextEditor hide some contents
StructuredTextEditor hide some contents [message #326164] Mon, 10 March 2008 03:56 Go to next message
Originally posted by: alexjaquet.gmail.com
I would like to know if it's possible to hide some text who are
displayed inside a StructureTextEditor.
For example I've the following text inside the editor at the beginin
<?xml version=\"1.0\" encoding=\"UTF-8\"?>
<!DOCTYPE xgui:module PUBLIC \"-TOTO-\" \"unknown.dtd\">
and I don't want to display it
(I want to have the code completion enabled)
Alexandre
Re: StructuredTextEditor hide some contents [message #326168 is a reply to message #326164] Mon, 10 March 2008 06:22 Go to previous messageGo to next message
Do I need to play with the ProjectionViewer setVisibleRegion ? If yes
how to work with ProjectionViewer and where to call this function ?
Alexandre
Re: StructuredTextEditor hide some contents [message #326169 is a reply to message #326168] Mon, 10 March 2008 06:43 Go to previous messageGo to next message
I've tryed the following code without success could someone point me
what's wrong
public void activateEditor() {
String str = "<?xml version=\"1.0\" encoding=\"UTF-8\"?><!DOCTYPE
xgui:module PUBLIC \"-TOTO-\" \"unknown.dtd\"";
boolean readOnly = true;
if (property != null) {
String v = property.getValue();
str = v == null ? "" : v;
readOnly = false;
// Update the contents of the InputStreamEditorInput
InputStreamEditorInput input = (InputStreamEditorInput) getEditorInput();
InputStream is = new ByteArrayInputStream(str.getBytes());
input.setContents(is);
input.setReadOnly(readOnly);
getSourceViewer().setVisibleRegion(str.length(),
getSourceViewer().getDocument().getLength());
// Finally update the user-interface
setInput(getEditorInput());
Re: StructuredTextEditor hide some contents [message #326171 is a reply to message #326169] Mon, 10 March 2008 08:35 Go to previous messageGo to next message
Alexandre,
Isn't this a WTP thing that's bested asked on the WTP newsgroup?
> what's wrong
> encoding=\"UTF-8\"?><!DOCTYPE xgui:module PUBLIC \"-TOTO-\"
> \"unknown.dtd\"";
> readOnly = false;
> getEditorInput();
Re: StructuredTextEditor hide some contents [message #326173 is a reply to message #326171] Mon, 10 March 2008 08:55 Go to previous messageGo to next message
you 're rigth
Re: StructuredTextEditor hide some contents [message #326185 is a reply to message #326168] Mon, 10 March 2008 13:13 Go to previous message
> Thanks
> Alexandre
Look for an article on code/text folding on Eclipse.org.
Previous Topic:Dynamically open a view and an editor
Next Topic:Menu label problems (seeing % names)
Current Time: Sun Oct 26 08:36:32 EDT 2025
Powered by FUDForum. Page generated in 0.05620 seconds
