No Products Available in Launcher To Launch a Product [message #326147] |
Sat, 08 March 2008 17:15 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: someone.microsoft.com
I have a relatively new Eclipse Classic 3.3 with Subclipse, CDT, and PyDev
installed on Linux. I am getting several projects for RCP apps from a
3rd-party Subversion. In the launcher configuration on the Main tab where
it says "Run a product", the only two available products are
org.eclipse.platform.ide and org.eclipse.sdk.ide. Normally, all the
products in the workspace are there.
They do not appear when I use "Launch an Eclipse Application" from the
Product Editor, Overview tab on any of the products. It uses the runtime
workbench instead (org.eclipse.platform.ide).
This is not an Eclipse problem as I have another workspace using the same
Eclipse that does show all the installed products (but they are different
products).
It is not a problem with the 3rd-party software as I have that running on
Windows, where there is no such problem. It is a moderately large project,
written by people who know what they are doing.
I've tried -clean.
So the question is how do I get Eclipse to recognize the .product files and
make them available in the launcher.
-Ken
Re: No Products Available in Launcher To Launch a Product [message #326153 is a reply to message #326147] |
Sat, 08 March 2008 21:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: zx.us.ibm.com
> and make them available in the launcher.
Does the plugin.xml that your product is in have an entry for the
product? ie.,
<extension
id="product"
point="org.eclipse.core.runtime.products">
<product
application="abc.application"
name="abc">
<property
name="appName"
value="abc">
</property>
</product>
</extension>
If you go to the overview page of your product configuration, there
should be an option to 'Synchronize.' This should ensure that you have a
proper extension to org.eclipse.core.runtime.products in your plug-in.
The only way I can see things not appear in the launch configuration is
if the org.eclipse.core.runtime products extension was bad...
By the way, I had a big kick out of your microsoft.com address, I hope
you don't mind ;)
http://mea-bloga.blogspot.com/2008/03/i-found-waldo.html
~ Chris
Re: No Products Available in Launcher To Launch a Product [message #326154 is a reply to message #326153] |
Sat, 08 March 2008 21:40 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Chris,
Thanks for the reply. Yes, the id="product" entry is there. (It works on
Windows.) Moreover, other products work in another Workspace so it isn't
org.eclipse.core.runtime products.
I didn't know what you meant by my microsoft.com address, but I now see it
is my return address. I think that was filled in by Outlook. (It sure
isn't keeping me from getting junk email ;-)
-Ken
"Chris Aniszczyk" <zx@us.ibm.com> wrote in message
news:fquvp2$ffr$1@build.eclipse.org...
> Does the plugin.xml that your product is in have an entry for the product?
> ie.,
> <extension
> id="product"
> <product
> name="abc">
> <property
> name="appName"
> value="abc">
> </property>
> </product>
> </extension>
> If you go to the overview page of your product configuration, there should
> be an option to 'Synchronize.' This should ensure that you have a proper
> extension to org.eclipse.core.runtime.products in your plug-in. The only
> way I can see things not appear in the launch configuration is if the
> By the way, I had a big kick out of your microsoft.com address, I hope you
> don't mind ;)
> Cheers,
> ~ Chris
FUDForum. Page generated in 0.03597 seconds
