Re: Menu label problems (seeing % names) [message #326159 is a reply to message #326139] |
Sun, 09 March 2008 13:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: malloovidio.bluewin.ch
Hi Jeff,
I guess you are defining the actual content of your menu labels in the
plugin.properties file. If so, try opening your plugin.xml file, switching
to the "build" tab in the plugin.xml editor and see whether the
plugin.properties file is marked to be included (at least) in the binary
build of your plug-in. If not, mark it and try whether this solves your
problem.
Hope that helps,
Ovidio
Jeff Johnston wrote:
> I am developing the Mylyn CDT plug-in and for some strange reason, my
> menu labels are appearing in their % form. For example, I have a menu
> label I refer to as: %FocusActiveTask.label. This key is found in my
> plugin.properties and is set to be "Focus Active Task". When I edit my
> plugin.xml, the string is resolved for me automatically when I look at
> the extensions. However, when I start up an Eclipse application from my
> workspace that uses my plugin, the menu label appears as
> I have plugin.properties specified in my binary build.
> I am using Eclipse 3.4 M5. Anybody have any ideas what I could look
> for/try?
Re: Menu label problems (seeing % names) [message #326160 is a reply to message #326159] |
Sun, 09 March 2008 13:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------020902060608020502080508
Ovidio,
Good advice. It's probably good to also make sure that this line
appears in the MANIFEST.MF:
Bundle-Localization: plugin
Ovidio Mallo wrote:
> Hi Jeff,
> switching
> problem.
> Hope that helps,
> Ovidio
>> menu label I refer to as: %FocusActiveTask.label. This key is found
>> in my plugin.properties and is set to be "Focus Active Task". When I
>> edit my plugin.xml, the string is resolved for me automatically when
>> I look at the extensions. However, when I start up an Eclipse
>> application from my workspace that uses my plugin, the menu label
>> appears as %FocusActiveTask.label.
>> for/try?
<html>
<head>
http-equiv="Content-Type">
</head>
Ovidio,<br>
<br>
Good advice.
Re: Menu label problems (seeing % names) [message #326188 is a reply to message #326187] |
Mon, 10 March 2008 20:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Jeff,
I looked for it and suspect it's hiding in one of those tabs somewhere,
but I couldn't find it...
> Ed Merks wrote:
>> Ovidio,
> Thanks Ed,
> I actually already did have the plugin.properties file in my binary
> build, but this little gem you mention works like a charm.
> Is there any way to make this show up without manually editing
> MANIFEST.MF (e.g. a tab option like Build, Overview etc..)?
FUDForum. Page generated in 0.03361 seconds
