Re: MultiText transparency + animations in Graphiti [message #1694810 is a reply to message #1694603] |
Fri, 08 May 2015 07:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Michael Wenz![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=michael.wenz%40sap.com) Messages: 1931 Registered: July 2009 Location: Walldorf, Germany |
Senior Member |
Jérôme,
thanks for that proposal, actually I also found several inconsistencies
between Text and MultiText shapes. And it is also true that for other shapes
some cleanup would be needed as well.
So, your proposals sound good to me and I think we should go for something
like that. The only thing I'm not sure about is the introduction of the
abstract base class all shapes can implement, that will be in conflict with
the current class hierarchy. It might be we have to use delegation here.
So, would you file an enhancement bug to track work on this? Not sure if we
can get this into the current release (Eclipse Mars in June) still, as we
are already quite far in the cycle, the milestone will be the first release
candidate...
Regarding anination: that sounds cool, looking forward to that. :-)
Michael
Powered by
FUDForum. Page generated in 0.04101 seconds
