Home » Eclipse Projects » Eclipse Platform » get the standard context menu on custom objects
get the standard context menu on custom objects [message #326006] Wed, 05 March 2008 10:17 Go to next message
I'm having a slight problem here figuring out how I get the standard
navigator context menu on my custom objects.
The contentprovider provides a hierarchy of
Project
Suite
objects and when I right-click on a suite I don't get any context menu.
So how can I let eclipse know that I'd like to get the same menu as for a
folder there?
Andreas
Re: get the standard context menu on custom objects [message #326009 is a reply to message #326006] Wed, 05 March 2008 10:28 Go to previous messageGo to next message
Andreas,
Maybe if the object is an IAdaptable and adapts to an IFolder.class it
will work...
Andreas Pakulat wrote:
> Project
> Suite
> folder there?
> Andreas
Re: get the standard context menu on custom objects [message #326010 is a reply to message #326009] Wed, 05 March 2008 10:58 Go to previous message
Ed Merks wrote:
> Andreas,
> will work...
That doesn't work unfortunately (though if I read the plugin.xml from
org.eclipse.ui.navigator.resource properly it should work). However I can't
do that anyway, as I'm working with objects that do not know they are
IFolders.
I'm just trying to find a way to do this without having to duplicate some
code from the ActionProviders in the eclipse plugins.
Andreas
Previous Topic:How to contribute a context menu to the Outline view
Next Topic:[DataBinding]
Current Time: Fri Apr 25 22:47:41 EDT 2025
Powered by FUDForum. Page generated in 0.03275 seconds
