Query -> Available Items; DB2 JDBC [message #325996] |
Wed, 23 January 2008 20:50 |
Originally posted by: kenneth.thornbrough.fnis.com
The only item being displayed in the "Available Items" list on the Query
window is the single DB2 JDBC data source entry I have defined. The
schemas and table names for the DB2 connection are not being listed. When
I test the connection it works fine and I have developed several dataset
definitions by manually writing the SQL which are working fine also.
I have releases 2.1.3 and 2.2.1.1 loaded and have the same problem with
both. While the preference options are slightly different between the
releases, I am using the defaults which have prefetch selected, 20
schema's, and 100 tables. For this particular DB2 connection, I should
get probably 15 schema's with around 75 tables each max.
I have searched the bug repository and didn't get any hits similar to this
or they were older than these releases and were listed as closed/fixed.
Any thoughts before I log a bug?
Thanks.
FUDForum. Page generated in 0.03317 seconds
