How to test internationalization plugin [message #325983] |
Wed, 05 March 2008 06:07 |
Originally posted by: sania12.yahoo.com
I have created a fragment project for internationalizing my plugin.
But I do not know how to test where the nl plugin created works..
Had a look at the tutorial "How to Test your Internationalized plugin" but
could not get much.
Thanks in advance
Sania
Re: How to test internationalization plugin [message #325985 is a reply to message #325983] |
Wed, 05 March 2008 07:20 |
Originally posted by: jacek.pospychala.pl.ibm.com
Sania,
Simplest way to test nl plugin is to launch your product with -nl
<language> and see if all looks ok.
Automated testing, i.e. automatic verification of properties files is I
think in scope of Babel project, which has recently started.
Sania wrote:
> Hi
> but could not get much.
> Thanks in advance
> Sania
Re: How to test internationalization plugin [message #326054 is a reply to message #325985] |
Thu, 06 March 2008 12:25 |
Originally posted by: chandra.mayamuthu.gmail.com
Hi sania,
If you have got answer for your question. Please reply me how did u
handle Double Byte Character Set in i18n, like Japanese language
characters.
Thanks in advance
Chandra M
Re: How to test internationalization plugin [message #326085 is a reply to message #326054] |
Fri, 07 March 2008 08:07 |
While running your application , open Run Dialog ---> Arguments tab-->
set the program argumnet for nl option ..
For example, for French set fr_FR like -nl fr_FR.. and run ur
application...
Sania
Re: How to test internationalization plugin [message #326105 is a reply to message #326085] |
Fri, 07 March 2008 11:51 |
Yes.. Sania, I did the same for French. Now my question is about double
byte characters handling. Example, Japanese letters are Double byte
characters, I am not able to save them in normal .properties files as we
used to for English and French, means we need to handle them in special
manner.
Please reply me.
Chandra M
FUDForum. Page generated in 0.04194 seconds
