Home » Eclipse Projects » Eclipse Platform » Chat within Eclipse
Chat within Eclipse [message #325963] Tue, 04 March 2008 07:17 Go to next message
Hi all,
First please let me know if there is a better place to ask such question
;o).
Is there any eclipse plugins ready to use in order to setup a chat between
several remote people working all the day with eclipse ?
Thanks in advance
Manu
http://manuelselva.wordpress.com
Re: Chat within Eclipse [message #325964 is a reply to message #325963] Tue, 04 March 2008 07:26 Go to previous messageGo to next message
--------------070602090201010202030903
Manuel,
I think ECF provides stuff like that: http://www.eclipse.org/ecf/
See also
http://mea-bloga.blogspot.com/2007/04/eclipse-irc-and-ecf.ht ml
There are a number of IRC groups, including #eclipse and #eclipse-dev
where folks hang out...
I use pidgin to connect...
Manuel Selva wrote:
> Hi all,
> question ;o).
> between several remote people working all the day with eclipse ?
> Thanks in advance
> Manu
<html>
<head>
http-equiv="Content-Type">
</head>
Manuel,<br>
<br>
Re: Chat within Eclipse [message #325965 is a reply to message #325963] Tue, 04 March 2008 07:28 Go to previous messageGo to next message
Maybe ECF?
http://www.eclipse.org/ecf/NewAndNoteworthy_2.0.0M4b.html
Tom
Manuel Selva schrieb:
> Hi all,
> ;o).
> Thanks in advance
> Manu
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Chat within Eclipse [message #325984 is a reply to message #325963] Wed, 05 March 2008 01:46 Go to previous messageGo to next message
Originally posted by: thunderaxiom.gmail.com
Manuel Selva skrev den 04-03-2008 13:17:
> Hi all,
> ;o).
I know you asked about an Eclipse plugin, so please just take this as an
input.
There is a facility in Netbeans which do exactly this, and also allow
you to "push" a project you are working on to your chat partners so they
can help you debug a problem.
I have played with it, but not used it for "real".
Thorbjørn
Re: Chat within Eclipse [message #326040 is a reply to message #325965] Thu, 06 March 2008 02:53 Go to previous messageGo to next message
Hi all,
In fact we need a way to chat each other with in the company. It's almost
sure that we won't be able to chat outside the company.
ECF can be used to do this ?
Manu
Re: Chat within Eclipse [message #326084 is a reply to message #325964] Fri, 07 March 2008 02:47 Go to previous messageGo to next message
Hi Ed,
I downloaded ECF and try to connect but nothing work. I think all the
ports used by IRC, XMPPS etc ... are blocked by the company firewall.
Do you know any easy way for me to setup a new IRC node and channel in
order to be able to chat with my colleagues with in the company ?
Manu
PS : i will try ECF clients at home of course ;o)
Re: Chat within Eclipse [message #326097 is a reply to message #326040] Fri, 07 March 2008 05:09 Go to previous messageGo to next message
Manuel Selva skrev den 06-03-2008 08:53:
> Hi all,
> almost sure that we won't be able to chat outside the company.
It is quite easy to set up a Jabber server locally inside your company,
and there are many jabber clients including a java applet (e.g.
https://jwchat.jabber.dk/).
I believe there might even be a vmware appliance for the purpose.
Thorbjørn
Re: Chat within Eclipse [message #326099 is a reply to message #326084] Fri, 07 March 2008 05:18 Go to previous messageGo to next message
Manuel,
I use pidgin. I don't really know much about how all this works. Nick
Boldt held my hand to set up the connections that allow me to hang out
on #eclipse-modeling
I've also included the ECF newsgroup on the "to" list of my reply so
they can offer help, though there's not much they can do to get around
your firewall issues.
Manuel Selva wrote:
> Hi Ed,
> Thanks
> Manu
Re: Chat within Eclipse [message #326133 is a reply to message #326099] Fri, 07 March 2008 12:23 Go to previous messageGo to next message
Ed Merks wrote:
> Manuel,
Pidgin can be configured to use an HTTP proxy to get around many
firewall issues. Perhaps ECF has similar capability...?
Eric
> Manuel Selva wrote:
>> Hi Ed,
>> Thanks
>> Manu
Re: Chat within Eclipse [message #326137 is a reply to message #326133] Fri, 07 March 2008 13:25 Go to previous messageGo to next message
Originally posted by: slewis.composent.com
Hi Eric,
Eric Rizzo wrote:
> Ed Merks wrote:
>> Manuel,
>> Nick Boldt held my hand to set up the connections that allow me to
>> hang out on #eclipse-modeling
Unfortunately, ECF does not support http tunneling for IRC at this point.
I've included on this email Christoph Schwering, who is the author of
IRCLib...which is the IRC communications library that ECF uses.
Christoph is actively working on IRCLib, and so hopefully will be able
to help us address this need.
I've also created this enhancement request to track this issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=221888
Thanks.
Scott
Re: Chat within Eclipse [message #326191 is a reply to message #326137] Tue, 11 March 2008 03:36 Go to previous message
Hi all,
First, thanks for your support.
In fact i think i'll never be able to connect to an IRC node outside the
company even if i can configure my client to go through the firewall ...
I think what i need is a way to set up an internal IRC "server" and
channels .. I don't know how IRC works ... is there any way to do this ?
Manu
Previous Topic:TitleAreaDialog message is cut off if it is longer than 2 lines
Next Topic:handleElementContentReplaced
Current Time: Fri Apr 25 17:55:03 EDT 2025
Powered by FUDForum. Page generated in 0.06705 seconds
