Home » Eclipse Projects » Eclipse Platform » Disposing listeners added to Selection service
Disposing listeners added to Selection service [message #325908] Mon, 03 March 2008 01:27 Go to next message
Originally posted by: swetha.yahoo.com
I have added few selection listeners in my perspective that contains many
views.
Now I want to remove these selection listeners when I switch perspective.
I am aware of the removeSelectionListener(IselectionListener) in
SelectionService.But the problem is that I do not have a reference of the
listener registered.
It could be easy for me if there is something like
removeAllSelectionListeners() in SelectionService.
Is there any way to remove all the selectionlisteners registered without
knowing their references.
Swetha
Re: Disposing listeners added to Selection service [message #325913 is a reply to message #325908] Mon, 03 March 2008 02:34 Go to previous messageGo to next message
I think such a method doesn't exist since listeners can be added from an
other part than yours and i will also delete these listeners ....
I think you have to keep your own references.
Manu
http://manuelselva.wordpress.com
Re: Disposing listeners added to Selection service [message #325920 is a reply to message #325913] Mon, 03 March 2008 07:36 Go to previous messageGo to next message
Manu,
Yes, I think the views that are listeners need to manage this
themselves. After all, all views might well be visible in the new
perspective as well since any view can be shown in any perspective using
Preferences->Show Viewer->Other...
Manuel Selva wrote:
> an other part than yours and i will also delete these listeners ....
> Manu
Re: Disposing listeners added to Selection service [message #325929 is a reply to message #325920] Mon, 03 March 2008 09:25 Go to previous message
Ed Merks wrote:
> Manu,
What Ed says is true, any listener you add you must remove at the
appropriate point in your lifecycle.
In 3.4 made the ISelectionService available through the getService(*)
mechanism. Any listeners you add will be cleaned up when your service
locator is disposed.
i.e. if you use workbenchWindow.getService(ISelectionService.class) to
get the selection service, your listeners would be cleaned up when the
workbenchWindow is closed. If you use
getSite().getService(ISelectionService.class) to get the selection
service, your listeners would be cleaned up when your part is disposed.
But if you were to use listeners at the "perspective" level, you would
probably get the ISelectionService from the workbenchWindow and you
would still be responsible for removing them when the perspective closes
(since it has a shorter lifecycle than the window, but a longer one that
your views).
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:extension points in org.eclipse.ltk.core.refactoring
Next Topic:property tester that returns true if a certain file exist on the project
Current Time: Sun Sep 14 23:03:17 EDT 2025
Powered by FUDForum. Page generated in 0.03782 seconds
