Home » Eclipse Projects » Eclipse Platform » How to get the command from a handler?
Re: How to get the command from a handler? [message #514335 is a reply to message #325904] |
Sun, 14 February 2010 16:23 |
Eugene Messages: 25 Registered: July 2009 |
Junior Member |
created this out by looking at some other threads:
protected Command getCommand() {
Command command = null;
IWorkbench workbench = PlatformUI.getWorkbench();
if(workbench != null) {
IWorkbenchWindow activeWorkbenchWindow = workbench.getActiveWorkbenchWindow();
if(activeWorkbenchWindow != null) {
Object service = activeWorkbenchWindow.getService(ICommandService.class);
if(service != null && service instanceof ICommandService) {
ICommandService commandService = (ICommandService)service;
//COMMAND_ID is defined in plugin.xml with defaultHandler class
command = commandService.getCommand(COMMAND_ID);
return command;
[Updated on: Sun, 14 February 2010 16:25] Report message to a moderator
Re: How to get the command from a handler? [message #514646 is a reply to message #514489] |
Tue, 16 February 2010 03:44 |
Daniel Krügler Messages: 853 Registered: July 2009 |
On 15.02.2010 16:12, Eugene wrote:
> Prakash G.R. wrote on Mon, 15 February 2010 01:25
>> On 13/02/10 5:17 AM, Eugene wrote:
>> > The problem with this is that I have no way to get the command in my
>> > handler. Does anyone have any hints for this?
>> Try executionEvent.getCommand();
>> - Prakash
>> Platform UI Team, IBM
>> Blog <http://blog.eclipse-tips.com>
>> Twitter <http://www.twitter.com/Eclipse_Tips>
> Hi Prakash,
> the execution event reference is only available through the handler "as
> it executes." Please take a look at this javadoc segment:
> The data object to pass to the command (and its handler) as it executes.
> You will notice that the only place the execution event is available is
> during the execute method:
> * Executes with the map of parameter values by name.
> * * @param event
> * An event containing all the information about the current
> * state of the application; must not be <code>null</code>.
> * @return the result of the execution. Reserved for future use, must be
> * <code>null</code>.
> * @throws ExecutionException
> * if an exception occurred during execution.
> Object execute(ExecutionEvent event) throws ExecutionException;
Your original description was quite misleading: By speaking
of "to get the command in my handler" it is most natural to
assume that you mean within the execute method.
So, after your correction, it seems, that you are not necessary
within a handler. Please give a short snippet to describe
your problem more specific. In which context are you working,
what is available?
Greetings from Bremen,
Daniel Krügler
Re: How to get the command from a handler? [message #514801 is a reply to message #514646] |
Tue, 16 February 2010 16:50 |
Junior Member |
Here is the description:
You have a toggle button in your UI. Depending on what is selected by the user, the button's state is reflected by the selection. For one item the button can be "on" and for the other item it can be "off."
To implement such behavior, we would have a class that implements IHandler (since we have a Command) and then since this command would respond to the selection, we need our class to also implement ISelectionChangedListener.
Note the methods of the IHandler interface:
public interface IHandler {
void addHandlerListener(IHandlerListener handlerListener);
public void dispose();
public boolean isEnabled();
public boolean isHandled();
void removeHandlerListener(IHandlerListener handlerListener);
Now we add in another method:
public void selectionChanged(SelectionChangedEvent event);
and our handler class now looks like this:
When our application starts and the user clicks on a selectable item WITHOUT activating the command first, the item may cause the button to have to update it's toggle state, which would require a reference to the command object. Unfortunately, the only way to get the command object, as Prakash has pointed out, is through the execution event, which we don't have since we are not executing the command.
Re: How to get the command from a handler? [message #514814 is a reply to message #514805] |
Tue, 16 February 2010 17:31 |
Junior Member |
Prakash G.R. wrote on Tue, 16 February 2010 12:04 | On 16/02/10 10:20 PM, Eugene wrote:
Have a look at the IElementUpdater. It helps to update the contribution.
- Prakash
www.eclipse-tips.com
My current implementation already implements the IElementUpdater to listen for when an editor or part changes. How can I get the currently selected item(s) (a list) to be sent through the IElementUpdater framework? Like I mentioned earlier, I am just using a selection listener at this point.
[Updated on: Tue, 16 February 2010 17:32] Report message to a moderator
Re: How to get the command from a handler? [message #514941 is a reply to message #514801] |
Wed, 17 February 2010 09:52 |
If I understand your design correctly, I'm not sure that it
is reasonable ;-) Obviously a handler has to register to
selection providers and that again would require that it is
created at a point where those selection providers become
active. So it looks to me, as if your handler should *not*
implement as selection observer, instead you use a different
object to realize that.
Regarding your question of getting a command: I do not
understand why you do not use the ICommandService for this,
which provides:
Command getCommand(String commandId);
HTH & Greetings from Bremen,
Daniel Krügler
Re: How to get the command from a handler? [message #514945 is a reply to message #514814] |
Wed, 17 February 2010 05:04 |
>> item
>> - Prakash
I'm really not sure that I understand your problem
correctly, but as I noted in another reply, I believe
you need to a different object that takes responsibility
of for selection observations. As a rough idea, you
could use a source provider for this and the source
provider is able to return the list of currently registered
selection providers. Either the source provider uses the
ICommandService to inform the Command or your command
handler uses the ISourceProviderService to get access to
your source provider (observer) and can obtain the
list of registered selection providers.
Does that solve your problem,
- Daniel
Re: How to get the command from a handler? [message #514956 is a reply to message #514945] |
Wed, 17 February 2010 10:36 |
Junior Member |
Daniel Krügler wrote on Wed, 17 February 2010 00:04 | On 16.02.2010 18:31, Eugene wrote:
>> item
>> - Prakash
- Daniel
Hi Daniel,
I believe that does solve my problem, however, the second approach you mentioned (getting the command service inside the handler) is the same approach I have implemented and documented above. Thank you for confirming I have done this correctly
Current Time: Sat Jul 27 16:11:17 GMT 2024
Powered by FUDForum. Page generated in 0.04604 seconds
