| Home » Eclipse Projects » Eclipse Platform » Creating a RCP Editor
 Goto Forum:|
| Creating a RCP Editor [message #325852] | Thu, 28 February 2008 22:05  |  |
| Eclipse User  |  |  |  |  | Originally posted by: asf14.yahoo.com
 I am in the process of writing a XML related editor as a tool for a
 research project, I want to reuse as many component of the Eclipse Java
 IDE workspace as much as possible, these probably include the resource,
 ide, console view etc packages. Has anyone done something similar
 before, whats the best way to replicate the basic functionality and
 where to start ? Any links or suggestions will be appreciated.
 Thanks, David
| Re: Creating a RCP Editor [message #325858 is a reply to message #325852] | Fri, 29 February 2008 06:22   |  |
| Eclipse User  |  |  |  |  | Originally posted by: merks.ca.ibm.com
 --------------020900080602030405050308
 David,
 The Web Tools project has an XML editor already.  How will your's
 differ?   Given a XML Schema for your XML syntax, EMF can generate fully
 functional integrated editor with just a few button clicks, so that
 might be a good way to start:
 Tutorial: Generating an EMF Model using XML Schema
 < http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.doc/tutorials/xlibmod/xlibmod.html>
 Dave wrote:
 > Hi
 > Java IDE workspace as much as possible, these probably include the
 > resource, ide, console view etc packages. Has anyone done something
 > similar before, whats the best way to replicate the basic
 > functionality and where to start ? Any links or suggestions will be
 > appreciated.
 > Thanks, David
 <html>
 <head>
 </head>
 David,<br>
 <br>
 fully functional integrated editor with just a few button clicks, so
 that might be a good way to start:<br>
 <blockquote><a
 href=" http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.doc/tutorials/xlibmod/xlibmod.html">Tutorial:
 Generating an EMF Model using XML Schema</a><br>
 </blockquote>
 <br>
 Dave wrote:
 <blockquote cite="mid:fq7spk$mgv$1@build.eclipse.org" type="cite">Hi
 <br>
 <br>
 <br>
 <br>
 Thanks, David
 <br>
 </blockquote>
 <br>
 </body>
 </html>
 --------------020900080602030405050308--
| Re: Creating a RCP Editor [message #325898 is a reply to message #325858] | Mon, 03 March 2008 00:39   |  |
| Eclipse User  |  |  |  |  | Originally posted by: dave.dave.com
 I am not writing a general XML editor, its for my own data specification
 in XML format. The RCP would contain algorithms and UI that would assist
 and manage these data.
 Regards, David
 Ed Merks wrote:
 > David,
 > Dave wrote:
 >> Hi
 >> appreciated.
 >> Thanks, David
| Re: Creating a RCP Editor [message #325899 is a reply to message #325898] | Sun, 02 March 2008 06:56   |  |
 --------------040900050602030806070501
 David,
 In that case, the RCP version of the EMF editor might be useful,
 although that's designed to avoid using a workspace:
 Tutorial: Generating a Rich Client Platform (RCP) Application Using
 EMF < http://www.eclipse.org/articles/Article-EMF-goes-RCP/rcp.htm l>
 In any case, it only take a few minutes to generate an EMF editor given
 a schema, so it seems like a good starting point if you're new to
 Eclipse since there's nothing like a fully functional starting point to
 get you off to the races quickly.  You might even find you want
 graphical views and that GMF will be able to generate those for you...
 > specification in XML format. The RCP would contain algorithms and UI
 > that would assist and manage these data.
 > Regards, David
 > Ed Merks wrote:
 >> David,
 >> Dave wrote:
 >>> Hi
 >>> appreciated.
 >>> Thanks, David
 <html>
 <head>
 </head>
 David,<br>
 <br>
 although that's designed to avoid using a workspace:<br>
 <blockquote><a target="_out"
 href=" http://www.eclipse.org/articles/Article-EMF-goes-RCP/rcp.htm l">Tutorial:
 Generating a Rich Client Platform (RCP) Application Using EMF</a><br>
 </blockquote>
 graphical views and that GMF will be able to generate those for you...<br>
 <br>
 <br>
 David wrote:
 <blockquote cite="mid:fqe0a3$gcp$1@build.eclipse.org" type="cite">I am
 not writing a general XML editor, its for my own data specification in
 <br>
 <br>
 Regards, David
 <br>
 <br>
 Ed Merks wrote:
 <br>
 <blockquote type="cite">David,
 <br>
 <br>
 <br>
 <br>
 <br>
 <a class="moz-txt-link-rfc2396E" href=" http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.doc/tutorials/xlibmod/xlibmod.html">< http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.doc/tutorials/xlibmod/xlibmod.html></a>
 <br>
 <br>
 <br>
 Dave wrote:
 <br>
 <blockquote type="cite">Hi
 <br>
 <br>
 <br>
 <br>
 Thanks, David
 <br>
 </blockquote>
 <br>
 </blockquote>
 </blockquote>
 <br>
 </body>
 </html>
 --------------040900050602030806070501--
 Current Time: Fri Oct 31 18:52:12 EDT 2025
 Powered by FUDForum . Page generated in 0.04821 seconds |
