Home » Eclipse Projects » Eclipse Platform » Creating a RCP Editor
Creating a RCP Editor [message #325852] Thu, 28 February 2008 22:05 Go to next message
Originally posted by: asf14.yahoo.com
I am in the process of writing a XML related editor as a tool for a
research project, I want to reuse as many component of the Eclipse Java
IDE workspace as much as possible, these probably include the resource,
ide, console view etc packages. Has anyone done something similar
before, whats the best way to replicate the basic functionality and
where to start ? Any links or suggestions will be appreciated.
Thanks, David
Re: Creating a RCP Editor [message #325858 is a reply to message #325852] Fri, 29 February 2008 06:22 Go to previous messageGo to next message
--------------020900080602030405050308
David,
The Web Tools project has an XML editor already. How will your's
differ? Given a XML Schema for your XML syntax, EMF can generate fully
functional integrated editor with just a few button clicks, so that
might be a good way to start:
Tutorial: Generating an EMF Model using XML Schema
< http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.doc/tutorials/xlibmod/xlibmod.html>
Dave wrote:
> Hi
> Java IDE workspace as much as possible, these probably include the
> resource, ide, console view etc packages. Has anyone done something
> similar before, whats the best way to replicate the basic
> functionality and where to start ? Any links or suggestions will be
> appreciated.
> Thanks, David
<html>
<head>
</head>
David,<br>
<br>
The Web Tools project has an XML editor already.&nbsp; How will your's
differ?&nbsp;&nbsp; Given a XML Schema for your XML syntax, EMF can generate
fully functional integrated editor with just a few button clicks, so
that might be a good way to start:<br>
<blockquote><a
href=" http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.doc/tutorials/xlibmod/xlibmod.html">Tutorial:
Generating an EMF Model using XML Schema</a><br>
</blockquote>
<br>
Dave wrote:
<blockquote cite="mid:fq7spk$mgv$1@build.eclipse.org" type="cite">Hi
<br>
<br>
<br>
<br>
Thanks, David
<br>
</blockquote>
<br>
</body>
</html>
--------------020900080602030405050308--
Re: Creating a RCP Editor [message #325898 is a reply to message #325858] Mon, 03 March 2008 00:39 Go to previous messageGo to next message
Originally posted by: dave.dave.com
I am not writing a general XML editor, its for my own data specification
in XML format. The RCP would contain algorithms and UI that would assist
and manage these data.
Regards, David
Ed Merks wrote:
> David,
> Dave wrote:
>> Hi
>> appreciated.
>> Thanks, David
Re: Creating a RCP Editor [message #325899 is a reply to message #325898] Sun, 02 March 2008 06:56 Go to previous messageGo to next message
--------------040900050602030806070501
David,
In that case, the RCP version of the EMF editor might be useful,
although that's designed to avoid using a workspace:
Tutorial: Generating a Rich Client Platform (RCP) Application Using
EMF < http://www.eclipse.org/articles/Article-EMF-goes-RCP/rcp.htm l>
In any case, it only take a few minutes to generate an EMF editor given
a schema, so it seems like a good starting point if you're new to
Eclipse since there's nothing like a fully functional starting point to
get you off to the races quickly. You might even find you want
graphical views and that GMF will be able to generate those for you...
> specification in XML format. The RCP would contain algorithms and UI
> that would assist and manage these data.
> Regards, David
> Ed Merks wrote:
>> David,
>> Dave wrote:
>>> Hi
>>> appreciated.
>>> Thanks, David
<html>
<head>
</head>
David,<br>
<br>
although that's designed to avoid using a workspace:<br>
<blockquote><a target="_out"
href=" http://www.eclipse.org/articles/Article-EMF-goes-RCP/rcp.htm l">Tutorial:
Generating a Rich Client Platform (RCP) Application Using EMF</a><br>
</blockquote>
get you off to the races quickly.&nbsp; You might even find you want
graphical views and that GMF will be able to generate those for you...<br>
<br>
<br>
David wrote:
<blockquote cite="mid:fqe0a3$gcp$1@build.eclipse.org" type="cite">I am
not writing a general XML editor, its for my own data specification in
<br>
<br>
Regards, David
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">David,
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp; Tutorial: Generating an EMF Model using XML Schema
<br>
&nbsp;&nbsp;&nbsp;
<a class="moz-txt-link-rfc2396E" href=" http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.doc/tutorials/xlibmod/xlibmod.html">&lt; http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.doc/tutorials/xlibmod/xlibmod.html&gt;</a>
<br>
<br>
<br>
Dave wrote:
<br>
<blockquote type="cite">Hi
<br>
<br>
<br>
<br>
Thanks, David
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------040900050602030806070501--
Re: Creating a RCP Editor [message #326254 is a reply to message #325852] Thu, 13 March 2008 05:28 Go to previous message
Dave wrote:
> Hi
> appreciated.
http://www.eclipse.org/eclipse/platform-text/development/rcp /examples/index.html
Dani
> Thanks, David
Previous Topic:how to position toolbar button in the main toolbar
Next Topic:Handling Double Byte Character Set in RCP
Current Time: Sun Apr 27 01:38:27 EDT 2025
Powered by FUDForum. Page generated in 0.03682 seconds
