Re: help not working? [message #325828 is a reply to message #325826] |
Thu, 28 February 2008 10:55 |
Michael,
Maybe there is a system property that specifies which browser to use and
that's not being found. Maybe you could start up a runtime workspace
and set a breakpoint in the code that's throwing this exception to learn
more... I wonder if a fresh install of Eclipse with nothing else
installed even has this problem?
Michael Moser wrote:
> I was trying to look up some info in eclipse's help system but for
> some strange reason, when I click Help => Help Contents then simply
> nothing happens. Same for Help => Search.
> The system log only shows a
> "org.eclipse.core.runtime.CoreException: Unable to retrieve system
> properties" (which it does since ages i.e. that's an exception I keep
> getting since at least eclipse 3.0 if not longer)
> and a
> " org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException "
> in some Mylyn bundle - again something that I have seen already since
> longer - so I doubt that this is the reason.
> Any idea, what could cause this?
> I'm using eclipse 3.3.1.1 on Win XP.
> Michael
Re: help not working? [message #325881 is a reply to message #325879] |
Fri, 29 February 2008 15:54 |
Michael,
I don't know much about it. Maybe someone else knows... Are there any
logged problems in the installation that's failing?
> http://download.eclipse.org/webtools/downloads/
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:fq63vi$8gg$2@build.eclipse.org...
>> Michael,
>> and that's not being found. Maybe you could start up a runtime
>> workspace and set a breakpoint in the code that's throwing this
>> exception to learn more... I wonder if a fresh install of Eclipse
>> with nothing else installed even has this problem?
> I changed Pref's => Help to use the internal browser, but no change.
> I then installed an eclipse 3.3.1.1 "proper", i.e. without a single
> add-on and fair enough here the help comes up. But of course that help
> doesn't contain the info I am seeking... :-(
> Is there a way to control the port on which the built-in tomcat
> listens? I would like to see if the problem is in the help server or
> in starting the browser and/or passing the URL (which one could - I
> guess - differentiate by directing a browser "manually" to the help
> port).
> Michael
FUDForum. Page generated in 0.03365 seconds
