Home » Eclipse Projects » Eclipse Platform » Remote debugging
Remote debugging [message #325808] Wed, 27 February 2008 20:14
Originally posted by: patrice.gauthier.2.ens.etsmtl.ca
At my work i'm working on a Eclipse plugin which must interacts with a
remote debugger in C++ that is used to execute XML scripts. I'm adding a
custom debug into my Eclipse plugin. But is the best options that the C++
application uses JPDA so i can use the remote java debug configuration to
debug the xml scripts?
Patrice
Previous Topic:EclipseCon - BoF - UI Component Programming Best Practices (SWT, Nebula, JFace, Databinding ...)
Next Topic:IEditorMatchingStrategy ignored
Current Time: Fri Nov 08 22:58:51 GMT 2024
Powered by FUDForum. Page generated in 0.02498 seconds
