PDE Builder not finding my plugin [message #325780] |
Tue, 26 February 2008 20:58 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: parrym.us.ibm.com
Hi, I'm having a problem with the PDE builder , apparently not finding
my plugin or the correct "version" of my plugin while trying to build a
feature headless. I've created a build.xml that I execute with ant in
which I invoke the PDE builder with the following java Ant task...
<java dir="${basedir}"
jar=" ${teamConcert.binaries}/eclipse/plugins/${org.eclipse.equino x.launcher} "
fork="true"
failonerror="false"
resultproperty="pdebuildReturnCode"
output="${pdebuild.log}">
<jvmarg value="-Xmx1024M" />
<arg line="-data ${working.dir}/workspace" />
<arg line="-application org.eclipse.ant.core.antRunner" />
<arg line="-buildfile
${teamConcert.binaries}/eclipse/plugins/${pde.build}/scripts /build.xml " />
<arg line="-Dbuilder=${working.dir}" />
<arg value="-Dbase=${teamConcert.binaries}" />
<arg value="-DbaseLocation=${teamConcert.binaries}/eclipse" />
<arg value="-DbuildId=${buildId}" />
<arg value="-DbuildDirectory=${working.dir}" />
</java>
PDE appears to get invoked but ultimately complains with the following
error message.
BUILD FAILED
/opt/IBM/jazz/client/eclipse/plugins/org.eclipse.pde.build_3 .3.1.v20070828/scripts/build.xml:24:
The following error occurred while executing this line:
/opt/IBM/jazz/client/eclipse/plugins/org.eclipse.pde.build_3 .3.1.v20070828/scripts/build.xml:64:
/opt/ibm/jazz/client/eclipse/plugins/org.eclipse.pde.build_3 .3.1.v20070828/templates/headless-build/customTargets.xml:10 :
/opt/ibm/jazz/buildsystem/buildengine/eclipse/fetched/workin g.dirs/I20080226-1316/allElements.xml:12:
/opt/ibm/jazz/client/eclipse/plugins/org.eclipse.pde.build_3 .3.1.v20070828/scripts/genericTargets.xml:85:
Unable to find plug-in: com.ibm.stg.wvcm.cmvc_0.0.0. Please check the
error log for more details.
My feature is set to synchronize versions during build. The file system
structure where I'm trying to build out of looks like this....
-bash-3.00$ ls -l
total 24
-rw-r--r-- 1 root root 1816 Feb 26 13:16 allElements.xml
-rw-r--r-- 1 root root 283 Feb 26 13:16 build.properties
drwxr-xr-x 3 root root 4096 Feb 26 13:16 features
drwxr-xr-x 2 root root 4096 Feb 26 13:16 logs
drwxr-xr-x 6 root root 4096 Feb 26 13:16 plugins
drwxr-xr-x 3 root root 4096 Feb 26 13:16 workspace
-bash-3.00$ ls -l features
total 4
drwxr-xr-x 2 root root 4096 Feb 26 13:16 com.ibm.stg.wvcm.cmvc.feature
-bash-3.00$ ls -l plugins
total 16
drwxr-xr-x 4 root root 4096 Feb 26 13:16 com.ibm.rational.wvcm.ri
drwxr-xr-x 4 root root 4096 Feb 26 13:16 com.ibm.rational.wvcm.tck
drwxr-xr-x 5 root root 4096 Feb 26 13:16 com.ibm.stg.wvcm.cmvc
drwxr-xr-x 5 root root 4096 Feb 26 13:16 javax.wvcm
Can anyone shed any light?
--Mark
Re: PDE Builder not finding my plugin [message #325783 is a reply to message #325780] |
Tue, 26 February 2008 23:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> fork="true"
> failonerror="false"
> </java>
> error message.
> BUILD FAILED
> -bash-3.00$ ls -l
> total 24
> total 4
> total 16
> --Mark
After additional investigation it appears this only happens if I set my
feature to "Synchronize versions on build". If I force the version from
the feature I do not get this error. This is using eclipse
3.3.1.R33x_r20070911
--Mark
Re: PDE Builder not finding my plugin [message #325809 is a reply to message #325783] |
Wed, 27 February 2008 21:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: Martin4010.hotmail.com
Did you remember to do some voodo and dance around your computer.
PDE Build is pure magic and must be treated that way ;-)
/M
"Mark D. Parry" <parrym@us.ibm.com> skrev i meddelandet
news:fq25oj$9m0$1@build.eclipse.org...
>> Hi, I'm having a problem with the PDE builder , apparently not finding my
>> fork="true"
>> failonerror="false"
>> </java>
>> error message.
>> BUILD FAILED
>> -bash-3.00$ ls -l
>> total 24
>> total 4
>> total 16
>> --Mark
> --Mark
FUDForum. Page generated in 0.03357 seconds
