Home » Eclipse Projects » Eclipse Platform » key binding in editor does not work in eclipse 3.4
Re: key binding in editor does not work in eclipse 3.4 [message #325757 is a reply to message #325733] |
Tue, 26 February 2008 13:47 |
nick tan Messages: 56 Registered: July 2009 |
Member |
Daniel Megert wrote:
> Nick Tan wrote:
>> Hi, all:
>> I recently migrate to eclipse 3.4. from 3.3, every thing works fine
>> except that
>> key binding in my xml editor does not work any more, like "ALT + SHIFT
>> + R" for renaming in file,
>> "ALT + ?" for content assist, "CTRL + O" for quick outline etc...
>> Whatever, it works fine in eclipse 3.3!
>> Did I miss anything?
> What is "my xml editor"? Anything in .log (e.g. key binding conflicts)?
> Dani
>> Thanks in advance & Best Regards!
>> Nick
Thanks for reply!
I implement my own xml editor, and retarget actions content assist, rename
in file etc. by overriding
org.eclipse.ui.editors.text.TextEditor.createActions() and extend
org.eclipse.ui.editors.text.TextEditorActionContributor
PS: no errors in .log and no key binding conflicts at all.
code snippets:
// com.bluebamboo.bluetools.xmleditor.editor.XmlEditor#createAc tions()
* @see org.eclipse.ui.texteditor.AbstractTextEditor#createActions()
protected void createActions() {
super.createActions();
ResourceBundle bundle = getEditorResourceBundle();
IAction action = new ContentAssistAction(bundle,
"ContentAssistProposal.", this);
action
..setActionDefinitionId(ITextEditorActionDefinitionIds.CONTE NT_ASSIST_PROPOSALS);
setAction("ContentAssistProposal", action);
action = new TextOperationAction(bundle,
"ContentFormat.", this, ISourceViewer.FORMAT); //$NON-NLS-1$
action.setActionDefinitionId(IJavaEditorActionDefinitionIds. FORMAT);
setAction("ContentFormat", action); //$NON-NLS-1$
action = new OpenDeclarationAction(this);
setAction("OpenDeclaration", action); //$NON-NLS-1$
action = new RenameInFileAction(this);
action
..setActionDefinitionId("com.bluebamboo.bluetools.xmleditor.renameInFile ");
//$NON-NLS-1$
setAction("renameInFile", action); //$NON-NLS-1$
// Create the quick outline action
createQuickOutlineAction(bundle);
// com.bluebamboo.bluetools.xmleditor.editor.XmlEditorActionCon tributor
* @see
IEditorActionBarContributor#setActiveEditor(org.eclipse.ui.I EditorPart)
public void setActiveEditor(IEditorPart part) {
super.setActiveEditor(part);
ITextEditor editor = null;
if (part instanceof ITextEditor) {
editor = (ITextEditor) part;
fContentAssistProposal.setAction(getAction(editor,
"ContentAssistProposal")); //$NON-NLS-1$
fContentFormat.setAction(getAction(editor, "ContentFormat"));
//$NON-NLS-1$
if (fToggleMarkOccurrencesAction != null) {
fToggleMarkOccurrencesAction.setEditor(editor);
if (editor instanceof XmlEditor) {
XmlEditor xmlEditor = (XmlEditor) editor;
fOpenDeclarationAction = new OpenDeclarationAction(xmlEditor);
contributeToMenu(getActionBars().getMenuManager());
fOpenDeclarationAction.setEditor(xmlEditor);
Re: key binding in editor does not work in eclipse 3.4 [message #325791 is a reply to message #325757] |
Wed, 27 February 2008 08:45 |
Dani Megert Messages: 3802 Registered: July 2009 |
>> Nick Tan wrote:
>>> Hi, all:
>>> except that
>> Dani
>>> Nick
> Thanks for reply!
Which editor class do you subclass? Did you define your own key binding
context? I suggest to debug it using the tracing options:
http://wiki.eclipse.org/Platform_Command_Framework#Tracing_O ption
Dani
> code snippets:
> action
> .setActionDefinitionId(ITextEditorActionDefinitionIds.CONTEN T_ASSIST_PROPOSALS);
> action
> //$NON-NLS-1$
> * @see
> //$NON-NLS-1$
Current Time: Fri Sep 13 07:45:27 GMT 2024
Powered by FUDForum. Page generated in 0.05198 seconds
