Home » Eclipse Projects » Eclipse Platform » org.eclipse.ui.ide.resourceFilters don't work any more?
org.eclipse.ui.ide.resourceFilters don't work any more? [message #325717] Mon, 25 February 2008 15:37 Go to next message
Does the org.eclipse.ui.ide.resourceFilters extension point still work? It's
still supported?
I add a variety of these filters in my plugin and none of them show up when I
look at the "Filters..." dialog for the Resource Navigator. It doesn't matter
which perspective I have open.
resourceFilters are still documented but looking in the Eclipse sources I see
that only the ".*" and "*.class" filters are still defined in any of the .xml
files and those filters don't show up anywhere either.
What is the replacement mechanism? How do I supply filters to the Resource
Navigator? I'm using Eclipse 3.3 at this point.
Gary
Re: org.eclipse.ui.ide.resourceFilters don't work any more? [message #325765 is a reply to message #325717] Tue, 26 February 2008 10:18 Go to previous message
AFAIK it works in 3.3.0 and is busted in 3.3.1 and fixed in 3.3.2 (soon
to be out, available as the latest M builds)
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:LaunchConfiguration & "IProcess of a my own class"
Next Topic:Drop Down Menu in own View
Current Time: Sat Apr 26 00:29:55 EDT 2025
Powered by FUDForum. Page generated in 0.02780 seconds
