Home » Eclipse Projects » Eclipse Platform » Cell selection in a tableviewer
Cell selection in a tableviewer [message #325677] Mon, 25 February 2008 11:38 Go to next message
i have more than one cell in a line. Now i want to select the second or
the third cell in this line. What code i need to make this possilble?
Greetings
Re: Cell selection in a tableviewer [message #325682 is a reply to message #325677] Mon, 25 February 2008 11:56 Go to previous messageGo to next message
Jörg,
I've not used it yet, but I think org.eclipse.swt.custom.TableCursor
would be used for that purpose.
Jörg wrote:
> Hello,
> or the third cell in this line. What code i need to make this possilble?
> Greetings
Re: Cell selection in a tableviewer [message #325688 is a reply to message #325682] Mon, 25 February 2008 12:07 Go to previous messageGo to next message
There are multiple possibilities since 3.3. SWT-Tables and Trees don't
have the idea of a Cell. That's why JFace holds a bunch of code to make
such a feature available to you (although we don't support SWT.MULTI).
Take a look at the various snippets:
http://wiki.eclipse.org/JFaceSnippets#Snippet026TreeViewerTa bEditing
Tom
Ed Merks schrieb:
> Jörg,
> Jörg wrote:
>> Hello,
>> Greetings
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Cell selection in a tableviewer [message #325703 is a reply to message #325688] Mon, 25 February 2008 13:07 Go to previous messageGo to next message
Thanks for your help. Both method does what i want. I have it now done
with the focusCellManager. But a little problem exist here, I got the
columnindex with this focusCellManager.getFocusCell().getColumnIndex(),
but how can i get the index of the row?
> Tom
> Ed Merks schrieb:
>> Jörg,
>> Jörg wrote:
>>> Hello,
>>> Greetings
Re: Cell selection in a tableviewer [message #325705 is a reply to message #325703] Mon, 25 February 2008 13:11 Go to previous message
This is not possible. SWT doesn't has direct API to fetch the row-index
and for viewers it is most of the time not important because the
Model-Object should hold all the data but you could easily calculate it
from the Cell-Bounds or even better if you are in-single-select-mode
(which you must :-) query to the table for the current-selection-index.
Tom
>> make such a feature available to you (although we don't support
>> SWT.MULTI).
>> Tom
>> Ed Merks schrieb:
>>> Jörg,
>>> Jörg wrote:
>>>> Hello,
>>>> possilble?
>>>> Greetings
Previous Topic:ErrorSupportProvider and UI for ErrorDialog
Next Topic:setSelection() in Virtual Table misbehaves
Current Time: Wed Mar 12 00:40:54 EDT 2025
Powered by FUDForum. Page generated in 0.04770 seconds
