Home » Eclipse Projects » Eclipse Platform » Binding label from command addition
Binding label from command addition [message #325676] Mon, 25 February 2008 11:38 Go to next message
In switching over some menus to commands I came across the following
problem
I have a popup menu contribution that I've added through the
org.eclipse.ui.menus extension point, to which I have attached a command.
Adding this command allowed me to declare icons and a label for the
command on the menu. It also picked up at runtime that the command had an
associated binding so it added that to the menu item as well.
Picking up the bindings is certainly a great feature but the problem I'm
having is I don't like the label Eclipse decided to use for that binding.
In my case I'm running on Windows Vista on a US - English locale, the
binding is to 'DEL' which is then displayed as 'Delete' on the menu. Is
there a way to change this display for the binding? There doesn't appear
to be anything on the bindings extension point to support an
internationalized label.
Any help would be much appreciated.
Thanks!
Re: Binding label from command addition [message #325681 is a reply to message #325676] Mon, 25 February 2008 11:54 Go to previous messageGo to next message
Ben,
My keyboard calls the key Delete in one place and "Del" in another (as
with Insert and Ins). I believe all these will appear in a .properties
file somewhere and would be translated if you had the translation
fragments installed (which aren't available for Eclipse 3.3). Generally
translation is done by using %<key> in the plugin.xml, specifying
Bundle-Localization: plugin in the MANIFEST.MF, and the defining that
<key> in plugin.properties.
> problem
> command. Adding this command allowed me to declare icons and a label
> for the command on the menu. It also picked up at runtime that the
> command had an associated binding so it added that to the menu item as
> well.
> I'm having is I don't like the label Eclipse decided to use for that
> binding.
> Is there a way to change this display for the binding? There doesn't
> appear to be anything on the bindings extension point to support an
> Thanks!
Re: Binding label from command addition [message #325693 is a reply to message #325681] Mon, 25 February 2008 12:19 Go to previous messageGo to next message
Yeah, thats exactly what I'm looking for for the ui.bindings extension
point. However, a label isn't defined for bindings in the schema.
I'm currently using the method you specified for internationalizing my
labels for the command additions to the menus, it's just those pesky
bindings that are still eluding me.
It's also quite possible, like you said, that the internationalization is
already defined for the DEL sequence somewhere down in the platform code
(like it does for M1 translating to Ctrl on Windows). In which case I'd
probably have to bite the bullet and stick with 'Delete', or log a bug I
guess.
Re: Binding label from command addition [message #325709 is a reply to message #325676] Mon, 25 February 2008 13:24 Go to previous messageGo to next message
In JFace I think it's about platform, not language ... and there's a
good chance it's getting its information from
/org.eclipse.jface/src/org/eclipse/jface/bindings/keys/forma tting/AbstractKeyFormatter.properties
That's where I see a map from DEL to Delete, but that's also a resource
bundle AFAICT.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Binding label from command addition [message #325713 is a reply to message #325709] Mon, 25 February 2008 13:43 Go to previous message
Ah, yep, looks like thats it, stuck with 'Delete' it is then.
Thanks Paul
Previous Topic:setSelection() in Virtual Table misbehaves
Next Topic:I want a part like the VE's palette
Current Time: Thu Oct 23 09:03:14 EDT 2025
Powered by FUDForum. Page generated in 0.06463 seconds
