Home » Eclipse Projects » Eclipse Platform » Problem running Eclipse
Problem running Eclipse [message #325663] |
Mon, 25 February 2008 13:40 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: xxx.yyy.zz
Hi all,
i've just updated Eclipse adding PDE + JDT and Eclipse doesn't run no more.
Please help me !!
Attached the log file.
SteM
Re: Problem running Eclipse [message #325666 is a reply to message #325663] |
Mon, 25 February 2008 13:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
SteM,
It looks like you've installed a 3.3 update in a 3.2 environment.
Perhaps you can delete all the 3.3 plugins from the plugins folder and
restart with a -clean to recover...
SteM wrote:
> Hi all,
> Please help me !!
> SteM
Re: Problem running Eclipse [message #325672 is a reply to message #325666] |
Mon, 25 February 2008 16:23 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
If I opened the About page I see 3.3.0 version, but the updater proposed me
only 3.2 patches (???)
I deleted both the plugins and features folders from the last updates but I
have again problems :-(
SteM
"Ed Merks" <merks@ca.ibm.com> ha scritto nel messaggio
news:fpuh73$771$1@build.eclipse.org...
> SteM,
> SteM wrote:
> > Hi all,
more.
> > Please help me !!
> > SteM
Re: Problem running Eclipse [message #325679 is a reply to message #325672] |
Mon, 25 February 2008 16:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------060602030309040506030504
SteM,
Does com.zylin.embeddedcdt_2.0.6 depend on Eclipse 3.3 but you're
installing in in Eclipse 3.2?
> SteM
>> SteM,
>> SteM wrote:
>>> Hi all,
> more.
>>> Please help me !!
>>> SteM
<html>
<head>
</head>
SteM,<br>
<br>
installing in in Eclipse 3.2?<br>
<br>
<br>
SteM wrote:
<blockquote cite="mid:fpuq1d$mv5$1@build.eclipse.org" type="cite">
<pre wrap="">If I opened the About page I see 3.3.0 version, but the updater proposed me
SteM
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> ha scritto nel messaggio
<a class="moz-txt-link-freetext" href="news:fpuh73$771$1@build.eclipse.org">news:fpuh73$771$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">SteM,
SteM wrote:
</pre>
<pre wrap="">Hi all,
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->more.
</pre>
<pre wrap="">Please help me !!
SteM
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------060602030309040506030504--
Re: Problem running Eclipse [message #325735 is a reply to message #325679] |
Tue, 26 February 2008 09:15 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
------=_NextPart_000_002B_01C87860.9287B560
charset="iso-8859-1"
Thanks Ed,
since i'm not really sure which is the version of Eclipse :-( i =
reinstalled the last package i own.
Now when Eclipse starts i see the spash saying 'Europa' (before was =
'3.3'), it asks me the workspace and then dies.=20
In the .metadata directory of the workspace i found the log that says:
!SESSION 2008-02-26 10:00:28.359 =
eclipse.buildId=3DM20071023-1652
java.version=3D1.6.0_03
java.vendor=3DSun Microsystems Inc.
BootLoader constants: OS=3Dwin32, ARCH=3Dx86, WS=3Dwin32, NL=3Dit_IT
Framework arguments: --clean
Command-line arguments: -os win32 -ws win32 -arch x86 --clean
!ENTRY org.eclipse.ui 4 4 2008-02-26 10:00:33.984
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2008-02-26 10:00:34.000
!MESSAGE The handle object must not have a zero-length identifier
!STACK 0
java.lang.IllegalArgumentException: The handle object must not have a =
at =
org.eclipse.core.commands.common.HandleObjectManager.checkId (HandleObject=
Manager.java:60)
at =
org.eclipse.jface.bindings.BindingManager.getScheme(BindingM anager.java:1=
498)
at =
org.eclipse.ui.internal.keys.BindingPersistence.readActiveSc heme(BindingP=
ersistence.java:401)
at =
org.eclipse.ui.internal.keys.BindingPersistence.read(Binding Persistence.j=
ava:1115)
at =
org.eclipse.ui.internal.keys.BindingService.readRegistryAndP references(Bi=
ndingService.java:208)
at =
org.eclipse.ui.internal.Workbench.initializeDefaultServices( Workbench.jav=
a:1249)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1062)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1847)
at =
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:41=
9)
at =
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at =
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hod(EclipseAp=
pContainer.java:572)
at =
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.ja=
va:171)
at =
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplicati=
on(EclipseAppLauncher.java:106)
at =
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Eclips=
eAppLauncher.java:76)
at =
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:3=
63)
at =
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:1=
76)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
SteM
"Ed Merks" <merks@ca.ibm.com> ha scritto nel messaggio =
news:fpurii$na3$2@build.eclipse.org...
SteM,
Does com.zylin.embeddedcdt_2.0.6 depend on Eclipse 3.3 but you're =
SteM wrote:=20
If I opened the About page I see 3.3.0 version, but the updater proposed =
me
I deleted both the plugins and features folders from the last updates =
but I
SteM
SteM,
SteM wrote:
Hi all,
more.
Please help me !!
SteM
=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2800.1607" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Thanks Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>since i'm not really sure which is the =
version of=20
Eclipse :-( i reinstalled the last package i own.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Now when Eclipse starts i see the spash =
saying=20
'Europa' (before was '3.3'), it asks me the workspace and then=20
dies.</FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>In the .metadata directory of the =
workspace i found=20
the log that says:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>!SESSION 2008-02-26 10:00:28.359=20
-----------------------------------------------<BR>eclipse.buildId=3DM200=
71023-1652<BR>java.version=3D1.6.0_03<BR>java.vendor=3DSun=20
Microsystems Inc.<BR>BootLoader constants: OS=3Dwin32, ARCH=3Dx86, =
WS=3Dwin32,=20
NL=3Dit_IT<BR>Framework arguments: --clean<BR>Command-line =
arguments: =20
-os win32 -ws win32 -arch x86 --clean</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>!ENTRY org.eclipse.ui 4 4 2008-02-26=20
10:00:33.984<BR>!MESSAGE Unhandled event loop exception</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>!ENTRY org.eclipse.ui 4 0 2008-02-26=20
10:00:34.000<BR>!MESSAGE The handle object must not have a zero-length=20
identifier<BR>!STACK 0<BR>java.lang.IllegalArgumentException: The handle =
object=20
must not have a zero-length identifier<BR> at=20
Manager.java:60)<BR> at=20
498)<BR> at=20
ersistence.java:401)<BR> at=20
ava:1115)<BR> at=20
ndingService.java:208)<BR> at=20
a:1249)<BR> at=20
org.eclipse.ui.internal.Workbench.init(Workbench.java:1062)<BR > at=20
org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1847) <BR> at =
9)<BR> at=20
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149) <BR>&=
nbsp;at=20
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95) <BR=
> at=20
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)<BR> at=20
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)<BR> at=20
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown =
Source)<BR> at=20
java.lang.reflect.Method.invoke(Unknown Source)<BR> at=20
pContainer.java:572)<BR> at=20
va:171)<BR> at=20
on(EclipseAppLauncher.java:106)<BR> at=20
eAppLauncher.java:76)<BR> at=20
63)<BR> at=20
76)<BR> at=20
Source)<BR> at=20
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508) <BR> =
;at=20
org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)<BR > at=20
org.eclipse.equinox.launcher.Main.run(Main.java:1173)<BR></FONT ></DIV>
<DIV><FONT face=3DArial size=3D2></FONT><FONT face=3DArial =
size=3D2></FONT><FONT=20
face=3DArial size=3D2></FONT><BR>--<BR>SteM</DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
ha scritto nel messaggio <A=20
href=3D"news:fpurii$na3$2@build.eclipse.org">news:fpurii$na3$2@build.ecli=
pse.org</A>...</DIV>SteM,<BR><BR>Does=20
installing in in=20
Eclipse 3.2?<BR><BR><BR>SteM wrote:=20
<BLOCKQUOTE cite=3Dmid:fpuq1d$mv5$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">If I opened the About page I see 3.3.0 =
but I
SteM
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:merks@ca.ibm.com"><merks@ca.ibm.com></A> ha scritto =
nel messaggio
<A class=3Dmoz-txt-link-freetext =
href=3D"news:fpuh73$771$1@build.eclipse.org">news:fpuh73$771$1@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">SteM,
SteM wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi all,
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->more.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Please help me !!
SteM
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_002B_01C87860.9287B560--
Re: Problem running Eclipse [message #325748 is a reply to message #325735] |
Tue, 26 February 2008 12:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------000703020403050406060603
SteM,
Using Help->About Eclipse, you can see the version. You're running with
-clean and not --clean (double dash clean)? Note that when installing a
fresh install, it's never a good idea to install over top of an existing
install.
SteM wrote:
> Thanks Ed,
> eclipse.buildId=M20071023-1652
> java.version=1.6.0_03
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
> !STACK 0
> at
> org.eclipse.core.commands.common.HandleObjectManager.checkId (HandleObjectManager.java:60)
> at
> org.eclipse.jface.bindings.BindingManager.getScheme(BindingM anager.java:1498)
> at
> org.eclipse.ui.internal.keys.BindingPersistence.readActiveSc heme(BindingPersistence.java:401)
> at
> org.eclipse.ui.internal.keys.BindingPersistence.read(Binding Persistence.java:1115)
> at
> org.eclipse.ui.internal.keys.BindingService.readRegistryAndP references(BindingService.java:208)
> at
> org.eclipse.ui.internal.Workbench.initializeDefaultServices( Workbench.java:1249)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
> at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
> at
> org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hod(EclipseAppContainer.java:572)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:171)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
> SteM
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> ha scritto
> nel messaggio news:fpurii$na3$2@build.eclipse.org...
> SteM,
>> SteM
>>> SteM,
>>> SteM wrote:
>>>> Hi all,
>> more.
>>>> Please help me !!
>>>> SteM
<html>
<head>
</head>
SteM,<br>
<br>
with -clean and not --clean (double dash clean)? Note that when
installing a fresh install, it's never a good idea to install over top
of an existing install.<br>
<br>
<br>
SteM wrote:
<blockquote cite="mid:fq0lce$pnh$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2800.1607" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Thanks Ed,</font></div>
<div><font face="Arial" size="2">since i'm not really sure which is
the version of Eclipse :-( i reinstalled the last package i own.</font></div>
<div><font face="Arial" size="2">Now when Eclipse starts i see the
spash saying 'Europa' (before was '3.3'), it asks me the workspace and
then dies.</font> </div>
<div><font face="Arial" size="2">In the .metadata directory of the
workspace i found the log that says:</font></div>
<div> </div>
<div><font face="Arial" size="2">!SESSION 2008-02-26 10:00:28.359
-----------------------------------------------<br>
eclipse.buildId=M20071023-1652<br>
java.version=1.6.0_03<br>
java.vendor=Sun Microsystems Inc.<br>
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT<br>
Framework arguments: --clean<br>
Command-line arguments: -os win32 -ws win32 -arch x86 --clean</font></div>
<div> </div>
<div><font face="Arial" size="2">!ENTRY org.eclipse.ui 4 4 2008-02-26
10:00:33.984<br>
!MESSAGE Unhandled event loop exception</font></div>
<div> </div>
<div><font face="Arial" size="2">!ENTRY org.eclipse.ui 4 0 2008-02-26
10:00:34.000<br>
!MESSAGE The handle object must not have a zero-length identifier<br>
!STACK 0<br>
org.eclipse.core.commands.common.HandleObjectManager.checkId (HandleObjectManager.java:60) <br>
org.eclipse.jface.bindings.BindingManager.getScheme(BindingM anager.java:1498) <br>
org.eclipse.ui.internal.keys.BindingPersistence.readActiveSc heme(BindingPersistence.java:401) <br>
org.eclipse.ui.internal.keys.BindingPersistence.read(Binding Persistence.java:1115) <br>
org.eclipse.ui.internal.keys.BindingService.readRegistryAndP references(BindingService.java:208) <br>
org.eclipse.ui.internal.Workbench.initializeDefaultServices( Workbench.java:1249) <br>
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1062)<br >
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1847) <br>
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419) <br>
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149) <br>
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95) <br>
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)<br>
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)<br>
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)<br>
at java.lang.reflect.Method.invoke(Unknown Source)<br>
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hod(EclipseAppContainer.java:572) <br>
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:171) <br>
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106) <br>
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76) <br>
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363) <br>
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176) <br>
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508) <br>
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)<br >
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)<br>
</font></div>
<div><br>
--<br>
SteM</div>
<div> </div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" <<a moz-do-not-send="true"
href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>> ha scritto nel
messaggio <a moz-do-not-send="true"
href="news:fpurii$na3$2@build.eclipse.org">news:fpurii$na3$2@build.eclipse.org</a>...</div>
SteM,<br>
<br>
<br>
<br>
SteM
"Ed Merks" <a moz-do-not-send="true" class="moz-txt-link-rfc2396E"
<a moz-do-not-send="true" class="moz-txt-link-freetext"
</pre>
<pre wrap="">SteM,
SteM wrote:
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
SteM
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------000703020403050406060603--
Re: Problem running Eclipse [message #325769 is a reply to message #325748] |
Tue, 26 February 2008 15:30 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
------=_NextPart_000_0031_01C87894.E7B2D950
Ed,
thanks again.
Using -clean I'm able to run Eclipse.
Right now I have 'Europa'. About says 3.2.0 version.
Why 'Europa' ??=20
I noticed that there is a new Repository for 'Europa' flavour ...
What's the difference between 'classic' version (now i see the last =
3.3.1.1 version) and Europa ?
From where i can upgrade Eclipse ?
Thanks a lot !!
SteM
news:fq12ce$u8f$2@build.eclipse.org...
SteM,
Using Help->About Eclipse, you can see the version. You're running =
with -clean and not --clean (double dash clean)? Note that when =
installing a fresh install, it's never a good idea to install over top =
SteM wrote:=20
Thanks Ed,
In the .metadata directory of the workspace i found the log that =
says:
!STACK 0
java.lang.IllegalArgumentException: The handle object must not have =
at =
Manager.java:60)
at =
498)
at =
at =
ava:1115)
at =
at =
a:1249)
at =
9)
at =
at =
at =
at =
va:171)
at =
at =
at =
63)
at =
76)
SteM
SteM,
SteM wrote:=20
me
but I
SteM
SteM,
SteM wrote:
Hi all,
more.
Please help me !!
SteM
=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2800.1607" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>thanks again.</FONT><BR><FONT =
face=3DArial=20
size=3D2>Using -clean I'm able to run Eclipse.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Right now I have 'Europa'. About says =
3.2.0=20
version.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Why 'Europa' ??</FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>I noticed that there is a new =
Repository for=20
'Europa' flavour ...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>What's the difference between 'classic' =
version=20
(now i see the last 3.3.1.1 version) and Europa ?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>From where i can upgrade Eclipse =
?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks a lot =
!!</FONT><BR>--<BR>SteM</DIV>
<BLOCKQUOTE=20
href=3D"news:fq12ce$u8f$2@build.eclipse.org">news:fq12ce$u8f$2@build.ecli=
pse.org</A>...</DIV>SteM,<BR><BR>Using=20
with=20
installing a=20
fresh install, it's never a good idea to install over top of an =
existing=20
install.<BR><BR><BR>SteM wrote:=20
<BLOCKQUOTE cite=3Dmid:fq0lce$pnh$1@build.eclipse.org type=3D"cite">
<STYLE></STYLE>
<DIV><FONT face=3DArial size=3D2>since i'm not really sure which is =
the version=20
of Eclipse :-( i reinstalled the last package i own.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Now when Eclipse starts i see the =
spash saying=20
dies.</FONT> </DIV>
workspace i=20
found the log that says:</FONT></DIV>
<DIV> </DIV>
WS=3Dwin32,=20
NL=3Dit_IT<BR>Framework arguments: --clean<BR>Command-line=20
arguments: -os win32 -ws win32 -arch x86 --clean</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>!ENTRY org.eclipse.ui 4 4 =
2008-02-26=20
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>!ENTRY org.eclipse.ui 4 0 =
2008-02-26=20
10:00:34.000<BR>!MESSAGE The handle object must not have a =
zero-length=20
identifier<BR>!STACK 0<BR>java.lang.IllegalArgumentException: The =
handle=20
object must not have a zero-length identifier<BR> at=20
498)<BR> at=20
ava:1115)<BR> at=20
a:1249)<BR> at=20
9)<BR> at=20
nbsp;at=20
> at=20
sun.reflect.NativeMethodAccessorImpl.invoke0(Native =
Method)<BR> at=20
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown =
Source)<BR> at=20
Source)<BR> at=20
va:171)<BR> at=20
63)<BR> at=20
76)<BR> at=20
Method)<BR> at=20
Source)<BR> at=20
Source)<BR> at=20
;at=20
<DIV><BR>--<BR>SteM</DIV>
<DIV> </DIV>
<BLOCKQUOTE=20
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A href=3D"mailto:merks@ca.ibm.com"=20
moz-do-not-send=3D"true">merks@ca.ibm.com</A>> ha scritto nel =
messaggio=20
<A href=3D"news:fpurii$na3$2@build.eclipse.org"=20
moz-do-not-send=3D"true">news:fpurii$na3$2@build.eclipse.org</A>...</DIV>=
installing in=20
in Eclipse 3.2?<BR><BR><BR>SteM wrote:=20
but I
SteM
href=3D"mailto:merks@ca.ibm.com" =
moz-do-not-send=3D"true"><merks@ca.ibm.com></A> ha scritto nel =
messaggio
href=3D"news:fpuh73$771$1@build.eclipse.org" =
moz-do-not-send=3D"true">news:fpuh73$771$1@build.eclipse.org</A>...
</PRE>
SteM wrote:
</PRE>
</PRE>
SteM
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BLOCKQUOTE><BR></BLOCKQUOTE ></BODY>=
</HTML>
------=_NextPart_000_0031_01C87894.E7B2D950--
Re: Problem running Eclipse [message #325771 is a reply to message #325769] |
Tue, 26 February 2008 15:37 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
--------------000107060500080908020102
SteM,
Europa is just the name of the coordinated release that includes the
platform as well as a large number of the downstream projects.
Generally you could use the the coordinated releases update site to
update your plugins and to pick up additional capabilities from other
project. Europa is based on Eclipse 3.3 though...
http://wiki.eclipse.org/index.php/Europa_Build
SteM wrote:
> Ed,
> thanks again.
> Why 'Europa' ??
> Thanks a lot !!
> SteM
> nel messaggio news:fq12ce$u8f$2@build.eclipse.org...
> SteM,
> running with -clean and not --clean (double dash clean)? Note
> that when installing a fresh install, it's never a good idea to
> install over top of an existing install.
> SteM wrote:
>> Thanks Ed,
>> was '3.3'), it asks me the workspace and then dies.
>> says:
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> SteM
>> scritto nel messaggio news:fpurii$na3$2@build.eclipse.org...
>> SteM,
>> you're installing in in Eclipse 3.2?
>>> SteM
>>>> SteM,
>>>> SteM wrote:
>>>>> Hi all,
>>> more.
>>>>> Please help me !!
>>>>> SteM
<html>
<head>
</head>
SteM,<br>
<br>
project. Europa is based on Eclipse 3.3 though...<br>
<blockquote><a href="http://wiki.eclipse.org/index.php/Europa_Build">http://wiki.eclipse.org/index.php/Europa_Build</a><br>
</blockquote>
<br>
SteM wrote:
<blockquote cite="mid:fq1bas$8al$1@build.eclipse.org" type="cite">
<div><font face="Arial" size="2">Ed,</font></div>
<div><font face="Arial" size="2">thanks again.</font><br>
<font face="Arial" size="2">Using -clean I'm able to run Eclipse.</font></div>
<div><font face="Arial" size="2">Right now I have 'Europa'. About
says 3.2.0 version.</font></div>
<div><font face="Arial" size="2">Why 'Europa' ??</font> </div>
<div><font face="Arial" size="2">I noticed that there is a new
Repository for 'Europa' flavour ...</font></div>
<div><font face="Arial" size="2">What's the difference between
'classic' version (now i see the last 3.3.1.1 version) and Europa ?</font></div>
<div><font face="Arial" size="2">From where i can upgrade Eclipse ?</font></div>
<div> </div>
<div><font face="Arial" size="2">Thanks a lot !!</font><br>
--<br>
SteM</div>
<blockquote
href="news:fq12ce$u8f$2@build.eclipse.org">news:fq12ce$u8f$2@build.eclipse.org</a>...</div>
SteM,<br>
<br>
<br>
<br>
<style></style>
is the version of Eclipse :-( i reinstalled the last package i own.</font></div>
the spash saying 'Europa' (before was '3.3'), it asks me the workspace
and then dies.</font> </div>
the workspace i found the log that says:</font></div>
<div> </div>
<div> </div>
2008-02-26 10:00:33.984<br>
<div> </div>
2008-02-26 10:00:34.000<br>
!STACK 0<br>
</font></div>
<div><br>
--<br>
SteM</div>
<div> </div>
<blockquote
<div>"Ed Merks" <<a href="mailto:merks@ca.ibm.com"
moz-do-not-send="true">merks@ca.ibm.com</a>> ha scritto nel
messaggio <a href="news:fpurii$na3$2@build.eclipse.org"
moz-do-not-send="true">news:fpurii$na3$2@build.eclipse.org</a>...</div>
SteM,<br>
<br>
<br>
<br>
type="cite">
SteM
href="mailto:merks@ca.ibm.com" moz-do-not-send="true"><merks@ca.ibm.com></a> ha scritto nel messaggio
href="news:fpuh73$771$1@build.eclipse.org" moz-do-not-send="true">news:fpuh73$771$1@build.eclipse.org</a>...
</pre>
<pre wrap="">SteM,
SteM wrote:
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
SteM
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------000107060500080908020102--
Current Time: Tue Jul 16 13:04:54 GMT 2024
Powered by FUDForum. Page generated in 0.04359 seconds
