How to add jars and folders to classpath [message #325655] |
Mon, 25 February 2008 12:37 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: automatic.javalobby.org
We are developing a plugin, which requires jars and folders containing java files to be added to classpath. We thought of using preferences. However no idea how to modify classpath at runtime.
Does this require writing your own classloader or eclipse does provide some API.
Could you please point out, how to add jars or folders to classpath at runtime. Thanking you in advance.
dheer
Re: How to add jars and folders to classpath [message #325711 is a reply to message #325655] |
Mon, 25 February 2008 18:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: wharley.bea.com
"reindheer" <automatic@javalobby.org> wrote in message
news:8402208.14671203943056988.JavaMail.root@cp1.dzone.com...
> some API.
By "at runtime" do you mean after the application has already started, i.e.,
too late to change the classpath that you load the application with? If so,
then yes, AFAIK you will need to use your own classloader. You don't
actually need to write the classloader yourself, you can just use an
URLClassLoader.
FUDForum. Page generated in 0.03827 seconds
