Home » Archived » XML Schema Definition (XSD) » Initializing XSDSimpleTypeDefinition instances
Initializing XSDSimpleTypeDefinition instances [message #32938] Tue, 11 November 2003 13:11 Go to next message
Ed,
Possibly you can give me some insight into the "initialization" process when
instantiating a new XSDSimpleTypeDefinition. Specifically, when I create a
new List XSDSimpleTypeDefinition (XSDVariety.LIST) I can walk through the
logic used to add a XSDWhiteSpaceFacetImpl instance to the "facets" EList.
What I do not see is where the XSDWhiteSpaceFacet is added to the
"facetContents" EList. When this XSDSimpleTypeDefinition is written out
within an XMI resource I see the reference to this XSDWhiteSpaceFacet ( e.g.
facets="/2/FirstListType;SimpleDatatype=1/XSDWhiteSpaceFacet " ) but there is
no XSDWhiteSpaceFacet within the file to resolve this reference. Shouldn't
facetContents have this XSDWhiteSpaceFacet ? Is there something I am
missing ? Do I need to preform some type of reconciliation prior to writing
out the resource?
Thanks in advance,
Dennis
Re: Initializing XSDSimpleTypeDefinition instances [message #32973 is a reply to message #32938] Tue, 11 November 2003 15:06 Go to previous message
Dennis,
You should be adding to facetContents directly. You should never add to the
facets because it's a computed relation. Have a look at the code in
XSDPrototypicalSchema for working examples.
dfuglsang wrote:
> Ed,
> out the resource?
> Thanks in advance,
> Dennis
Re: Initializing XSDSimpleTypeDefinition instances [message #580708 is a reply to message #32938] Tue, 11 November 2003 15:06 Go to previous message
Dennis,
dfuglsang wrote:
> Ed,
> out the resource?
> Thanks in advance,
> Dennis
Previous Topic:Initializing XSDSimpleTypeDefinition instances
Next Topic:Allowed children of a XSDSimpleTypeDefinition
Current Time: Tue Oct 21 20:26:23 EDT 2025
Powered by FUDForum. Page generated in 0.04308 seconds
