ruler columns [message #325522] |
Wed, 20 February 2008 19:44  |
I am looking for some help/examples on how to add a vertical ruler column
to the editor.
I have already tried extending the
"org.eclipse.ui.workbench.texteditor.rulerColumns", however,
in order for my column to work, I have to modify / add code
to AbstractDecoratedTextEditor to handle initilizing my
new column. This way sort of works(column shows up as expected), however,
I would like to avoid having to modify the org.eclipse code.
Is there a way to add a column without modifying the
org.eclipse.. code. (i.e. via just extending)??
thanks
Nick
Re: ruler columns [message #325532 is a reply to message #325522] |
Thu, 21 February 2008 03:52  |
> column to the editor. I have already tried extending the
> "org.eclipse.ui.workbench.texteditor.rulerColumns", however, in order
> for my column to work, I have to modify / add code to
> however,
> Is there a way to add a column without modifying the org.eclipse..
See org.eclipse.ui.workbench.texteditor.rulerColumns extension point.
Dani
> thanks
> Nick
FUDForum. Page generated in 0.25447 seconds
