Re: Toolbar Launcher Defaults to Current File, Not Last Run [message #325538 is a reply to message #325519] |
Thu, 21 February 2008 14:30 |
Originally posted by: mark_melvin.amis.com
Yes, this is called contextual launching and is really quite good once you
get used to it. If you want, though you can revert it back to the old
behavior:
Window > Preferences > Run/Debug > Launching, and change the Launch
Operation setting.
M.
On Wed, 20 Feb 2008 14:21:02 -0500, Kenneth Evans <evans@aps.anl.gov>
wrote:
> At some point recently (Eclipse 3.3 ?) the behavior of the Run and Debug
> buttons on the Toolbar has changed. Before, the default (if you pushed
> the
> button without expanding the pull-down menu) was to run the last launch.
> Now it appears to try to run the file you are editing.
> This is not what I want (99% of the time it is not even meaningful to run
> that file). Is there a preference to change it?
> Any information would be appreciated.
> -Ken
FUDForum. Page generated in 0.05827 seconds
